Braided hose kit? Covers?
Old May 14, 2007 | 07:15 PM
pnandy's Avatar
pnandy
Default Braided hose kit? Covers?
Hey i've notcied that a few people on here have braided hosesand i wanted to know are there any places to buy a kit for the mustang or is the best thing to do just to buy a universal kit and cut it to size. Please post pics and name of the brand that you have thanks
Old May 14, 2007 | 07:21 PM
Arwing's Avatar
Arwing
Default RE: Braided hose kit? Covers?
+1
I really want to know too
Old May 14, 2007 | 07:24 PM
hammeron's Avatar
hammeron
i think the braided hoses are mentioned in the
engine bay pics thread.....
Old May 14, 2007 | 07:44 PM
hawgman's Avatar
hawgman
I ♥ Acer
Just buy bulk hose and connectors from Summit
Old May 14, 2007 | 07:53 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I am interested as well. Is it a P.I.A. project or a fairly simple one?
Old May 14, 2007 | 08:21 PM
sst06vert's Avatar
sst06vert
do they still use aeroquip like the old days?
Old May 14, 2007 | 08:24 PM
scramblr's Avatar
scramblr
I've posted this a bunch of times, so it's just copy and paste now. As mentioned though, Summit's prices are pretty good. ---
First go here, http://www.powerflowracing.com/spectre-catalog.asp and select "Plumbing" then "fuel hose". Determine all the part numbers needed and then to Autozone web site. You can probably walk into an Autozone and pick up this whole kit and the fittings will be red and blue. I only wanted blue fittings so I bought the hoses and fittings seperately.
Or you an go to each link below which are the parts I bought seperately.
5/16" line: http://www.powerflowracing.com/spect...il.asp?PD=752. It's 48" long and you cut it to the size you need and slip the other clamp on. Need one of these.
3/8" line: http://www.powerflowracing.com/spect...il.asp?PD=759. It's 72" long and you cut it to size also. Buy an extra set of clamps.
5/8" line: http://www.powerflowracing.com/spect...il.asp?PD=827. This one is 48" long and you cut it to size also. Need one of these as well.
The radiator overflow, passenger side PCV, fuel vaccum, and brake vaccum are 3/8", the fuel rail one is 5/16", and the big PCV on the driver's side is 5/8".
Then you can go here and pick out the part numbers of the clamps that you want if you don't pick up a kit. http://www.powerflowracing.com/spect...=15&PSG=53
Hope this helps. Oh yeah, you'll neel either a hacksaw (wrap that section of hose with tape first) or a Dremel to cut through the hoses. I used a Dremel and it cut right through. Let me know if you have questions.
Old May 14, 2007 | 08:41 PM
ADudeInNewJersey's Avatar
ADudeInNewJersey
Will thekit with the chrome fittings work??
-John
Old May 14, 2007 | 08:51 PM
scramblr's Avatar
scramblr
ORIGINAL: ADudeInNewJersey
-John
Which kit are you talking about?
Old May 15, 2007 | 12:47 AM
pnandy's Avatar
pnandy
Hey how hard of a project was this. Also was it time consuming and about how much did it cost you thanks for info Are yours real lines of just sleeves?
