Custom vs. Canned Tune
I just bought a Diablo tuner off a fellow MustangForum member. It already has a canned tune for my C&L Intake, but I was wondering what is the difference in the canned tune and say a custom tune I'd order from B a m a chips. How much more power would I expect from a B a m a tune, would the difference be noticable or worth it?
RE: Custom vs. Canned Tune
I would definetly go with B ama chips...!!! I just ordered a tune and I am hoping for the best. I have heard that a tune from B ama will REALLY open up an automatic (such as mine)... so if I were you, I would download a tune off of D oug's site and load it on to the hand held tuner you already have. I dont know how much more hp you will get. But, in general, he uses a totally different torque converter schedule as well as tuning all the parts you have on the car. Maybe I shouldnt talk so much before I even have my car tuned by B ama, but majority of the people on the forums like their B ama tunes...
Also, read this... one guy in there said he had a bad experience with B ama... probably just bad luck.
https://mustangforums.com/m_3218522/tm.htm
People will tell you there is a difference, but I'd like to see back-to-back dyno proof showing the custom tuner is better than Diablosport's "canned" tune with just an intake. I don't see how there could be much difference in a manual transmission application. You're air/fuel mix is either on or it's not.
In an auto, there are other parameters that may make it worth while to call b-a-m-a or another tuner.
ORIGINAL: Getaway
There is much more to a tune then just air/fuel ratio and shift points (for the auto). Anything you do yourself such as a bama or brenspeed tune i consider a canned tune. A custom tune is going on a dyno, and fine tuning EXACTLY to your car, these are the best way to go as no 2 cars are exactly the same.
Agreed, but people often consider vendors like b-ama and brenspeed "custom", the handheld manufacturer "canned", and a "dyno tune" something seperate. I think it's because vendors load their "custom" tunes into the "custom" storage spaceson the handheld tuner. Dyno tune would definitely be the way to go, or simply get a wideband and do some datalogging if you are proficient with your handheld.
ORIGINAL: ohsixgt1217
... Anything you do yourself such as a bama or brenspeed tune i consider a canned tune. A custom tune is going on a dyno, and fine tuning EXACTLY to your car, ...
Canned Tune: What comes pre-loaded on your handheld tuner (XCal2 or Predator)
Custom Tune: What Doug, Brenspeed, and others provide. You provide them with your current performance mods, and a tune is written for your car.
Dyno Tune: A more detailed tailoring of the custom tune which is performed from real time feedback from a dyno.
ORIGINAL: TacoBill
Disagree. [8D]
ORIGINAL: Scotte28516
I completely disagree with that.
I can assure you that Doug and others are changing more than 1 or 2 settings. I've seen his program tunes in person on his computer and it's amazing at the amount custom adjustments he makes that deviate from both the stock and preloaded programs.
I never attested that a mail order tune is better than a custom dyno tune. Of course, the latter is the way to go as long as the tuner knows what they're doing and you have the $$ to have it done. I'm not saying that it can't happen, but I have yet to read about an engine destroyed by running a tune from Doug or Brenspeed.
