whining while turning
Old May 17, 2007 | 08:24 AM
Goody625's Avatar
Goody625
Default RE: whining while turning
Rearend Gear whine = Clutch packs....again....There is a TSB on it(see TSB list above). Mine was doing it, Dealership fixed it....not doing it anymore.
Good luck
Old May 17, 2007 | 09:50 AM
NickSezz's Avatar
NickSezz
You guys don't know what he means....you keep hearing whine and thinkin tranny and diff...I have a 5-speed V6 and it does the same thing. It is deffinatly something in the steering column. Its more pronounced when its cold too. May be one day ill searchfor the cause.
Old May 17, 2007 | 10:28 AM
travis5049's Avatar
travis5049
Mine is making that same noise but its coming from the axle or dif...........................06 automatic w/3500 miles. and only when I turn. Noticed it coming back from FFW in Houston.
Old May 17, 2007 | 10:35 AM
07 Stang's Avatar
07 Stang
Ya know, I had the same thing happen to another car......it was low onpower stirringfluid. Once filled....no more whine.
Old May 17, 2007 | 11:07 AM
SOHCman's Avatar
SOHCman
We had the whine from the power steering in the wife's Windstar, she pulls off the highway and the TORSION BAR snapped!
Guess it was stressing the PS pump.
SOHC
PS: It was 6 miles from the dealer on the way home! They fixed it for free.
Old May 17, 2007 | 12:31 PM
Joe06's Avatar
Joe06
Mine does the same thing. It is the power steering pump making the noise. Seems to be worse when the engine is cold and slightly decreases as the engine warms up. Not too much of an annoyance. It may be just be the nature of the beast.
Old May 17, 2007 | 01:22 PM
offrdmania's Avatar
offrdmania
It is the power steering pump while under a pressure load. The lower the fluid level gets the louder it is. He stated that it was while turning. A gear whine would happen all the time, not just when turning
Old May 17, 2007 | 01:51 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: offrdmania
Not with the limited slip rearend. Notorious for whining only when turning. Especially after a long straight run on the interstate. Take the off ramp and turn one way or the other. They tend to scream like a raped ape.
Old May 17, 2007 | 02:26 PM
ALLCHEST's Avatar
ALLCHEST
mine only does this when I turn the wheel all the way in a certain direction - like a u turn.
Old May 17, 2007 | 03:19 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
Many cars have power-steering whine (at least most of the ones I've driven)
