whining while turning
Old May 16, 2007 | 03:07 PM
bermbasher's Avatar
bermbasher
Default whining while turning
i have an 06 and when i turn it makes a whining sound. any body know what it could be? makes it in both directions.
Old May 16, 2007 | 04:26 PM
NickSezz's Avatar
NickSezz
Default RE: whining while turning
I have the same thing...sounds like adry seal rubber on a metal shaft. I wouldnt worry too much but i would like to know what is is also.
Old May 16, 2007 | 04:32 PM
Blackhawk07's Avatar
Blackhawk07
most likely its your power steering..does it do it in slight turns ? Its normal for it to make a whining noise when the car is not moving.
Old May 16, 2007 | 05:14 PM
northy_polk's Avatar
northy_polk
most likely the clutch pack [if you have a manual]. there is a TSB for it. TSBs are listed on the main page at the top. basically, a dealership would install new clutchpacks and add friction modifier to stop the moan, or whine as you called it. the service foreman told me to just add the friction modifier myself because the fix that Ford was doing wasn't necessarily a permanent one. if you look up "rear end noise", "moan" or "groan" on this site you'll find a lot written about it. i added the friction modifier myself and have not had any more moan from the rear end now for about 3k miles.
Old May 16, 2007 | 05:28 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: northy_polk
From what I read, they are replaceing the clutch packs.
http://www.stangnet.com/images/stori...s/06-12-11.pdf
Old May 16, 2007 | 05:43 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
+1
ORIGINAL: Blackhawk07
Old May 16, 2007 | 06:41 PM
northy_polk
yeah, that's what i just said. that's what the TSB is for. but the bitch of the whole thing is that replacing them doesn't necessarily fix it because they are using the same parts!!! makes sense, huh?! not to me either.
Old May 16, 2007 | 06:45 PM
GidyupGo's Avatar
GidyupGo
Sorry about my inept reading of your last post. Yea, replacing the pack might get you another 30K miles or so. One of those things like oil changes except not as frequent.
Old May 16, 2007 | 07:02 PM
schmitty's Avatar
schmitty
clutch packs. just had mine done
Old May 17, 2007 | 04:07 AM
bermbasher's Avatar
bermbasher
sorry i didnt state that it is an auto, and the noise is from up front almost like a bearing. or something rubbing. thanks.
