One touch window not working!
Old May 18, 2007 | 07:58 PM
localgod_11's Avatar
localgod_11
Default One touch window not working!
[hr]
I just got my car back from 3 weeks in the shop due to an accident which cause more than 5k in front end damage!
The car USED TO have one touch up and down on bith the driver and passenger side windows now its only on the driver side!! How the hell do I fix this!!! I called the service guy and he says he only does collision and they didnt touch the passenegr window! Anyone have an idea I have a feeling these guys are gonna need a road map to fix this! I know that in the ECU somewhere there is a setting to make the windows roll down using the key fob could this be similar cause i know they took the battery off so maybe something got scrambled??
ALSO if there is anyone in 2-3hrs of Ft lauderdale with an OBD II scanner please drop be a line cause I would like to get the key fob function working!
Thanks for ANY help
Jerry[/align]
Old May 19, 2007 | 02:57 AM
Leoleo's Avatar
Leoleo
Default RE: One touch window not working!
Could be something he forgot to plug in. Something like this happened to my Freestyle. Tech needed to replug in a wire. Take in to a dealer, could be under warrenty.
Old May 19, 2007 | 03:08 AM
mlcrycc's Avatar
mlcrycc
Have you tried the "express up function" reset?? Page 45...
http://www.mustangblog.com/info/2006.ownersmanual.pdf
The key fob window control was only on the early 05's.....
Good luck,
Mike
Old May 19, 2007 | 03:36 AM
rmays06's Avatar
rmays06
Or try holding the switch in the up or down positions for like 2 seconds to see if it will reset.
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
MusicCity615
Sep 27, 2015 12:53 AM
jjwinel78
Aug 17, 2015 03:34 PM
Mustang Sally72
Aug 11, 2015 07:54 AM
