NEED MGW SHIFTER HELP
I was making adjustments to my MGW shifter and broke the bolt that goes from the trans link arm to the shifter. I'm guessing the only fix is getting a new trans link arm. Has anyone had this happen? This sux... any other suggestions? For those installing, be careful tightening this bolt. It is the 13mm lock nut that goes onto the trans link arm once you place it throught the hole in the shifter link arm.
RE: NEED MGW SHIFTER HELP
sorry TacoBill. i used your excellent pictures for reference to Gman. hope you dont mind. by the way, thanks to your excellent write up on this shifter, i ordered one yesterday. should be able to install next week. will let you know. hey Gman, sorry about the broken bolt. give us an update when you get it fixed.
ORIGINAL: ZZLEGEND
It's all good! If any of my pics helps out other members, by all means, reference them.
On that link arm stud, when I tightened down on that nut, I just moderately tightened it down. I didn't get crazy and really wrench down on it. Like George (at MGW) mentioned, it's a lock nut, so even is it isn't cranked down, it'll still hold.
junior04
09-28-2015 10:53 AM
