Pics of new motor and KB set-up...
RE: Pics of new motor and KB set-up...
Nice pics man!Can I ask youa question.I'm adding a KB within the next month and thinking of building a stroker forged short block this winter cause I don't drive her a whole lot when the weather gets crappy. I see you have some experience with this, just how would you recommend that I build it?
ORIGINAL: fordfanboy
THAT motor was due to a terrible set of heads form JDM Engineering. They forgot to replace the valve guides and left the stockers ground 1/2" short after the port job. Valve tapped a piston in the first 100 yards of driving it. It was a nasty ordeal and I ended up having to sue them over it and won. Lot of info about it on some other sites, but never talked about it much here. Obviously I am not a JDM fan...lol (see avatar)
ORIGINAL: moosestang
I must have missed the post of how you put a hole in your piston.
Suck that happened. Good it see her up and running!
ORIGINAL: Scotte28516
Wow! Your car was in Adam's shop when I had my Whipple installed, but your turbo was shot and he was putting a new one on for you. In 2 1/2 months you managed to blow it up and then actually made it into court to sue JDM and won?? You must have some great connections in the court to get your case in and heard so quickly. Why did you buy JDM heads in stead of having them done by Adam when having the motor fixed vy him anyway? Just curious. The destroyed turbo isn't what helped destroy the piston is it?
I didn't use adam for the heads cause he had never done a P/P job on a set of 3V heads before and I think porting is a science and wanted something from a known builder. I went with livernois for that reason. The first time a year ago I got the JDM heads onlhy cause they were in stock and livernoise was 10 weeks out and I had a shortblock ready to go. I had heard some good things about JDM and I know they are good saleen tuners so I made the mistake to try them on something out of their league.
None of my turbo set-ups were ever 'destroyed'. They actually all ran great at 11 psi. The 67mm just didn't make enough power and I just got tired of dealing with the insane heating issues when I turned 76mm up.
ORIGINAL: jerjan
Nice pics man! Can I ask youa question. I'm adding a KB within the next month and thinking of building a stroker forged short block this winter cause I don't drive her a whole lot when the weather gets crappy. I see you have some experience with this, just how would you recommend that I build it?
ORIGINAL: jerseystang07
what tires and sizes are you running? the cars looks great man
i forgot to ask, are you lowered? what set up are you using if you are?
Billet 18x10's and I run the Nitto 555R 305/45-18 out back and the NT555 up front. Yes. lowered about 1" with the eibachs.
Sweet.There are lots of gauges in it,isn't it?
The pyrometer was real important for the turbo but useless now that the turbo is gone but since I don't want a hole in my dash, I left it. I'll probably swap it to a intake temp gauge sometime in the future. Running big psi and already blowing up motors in the past - I want to know what the hell is going on in there...lol
