HURST SHIFTER
Old May 24, 2007 | 12:01 AM
BigDave's Avatar
BigDave
Default RE: HURST SHIFTER
ORIGINAL: Meek
I loved my T handle but grabbing it after been in the heat or cold is brutal.. switched it back to the white ball.
Dave
I like the reverse TSRUH branded into the palm of my hand...
Old May 24, 2007 | 12:18 AM
sst06vert's Avatar
sst06vert
ORIGINAL: Bluestar
Great shifter for the price, easy install. Re: the shifter being too short.....It wouldn't be a short throw shifter if it had a longer shaft....
oops what was i thinking? long dayt at work
Old May 24, 2007 | 12:22 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Great shifter from what I have read but I switched from the Steeda tri-ax to the MGW and it is the smoothest shifter on the market IMO.
Old May 24, 2007 | 01:07 AM
probinator's Avatar
probinator
If you need help, the guy I use only charges 50 for the install. But im in Ventura ca. Pm me if you need him.
just use lok tight and you will be ok. but its a nice upgrade and I think it just looks good.
Old May 24, 2007 | 01:23 AM
EmperorOfChicken's Avatar
EmperorOfChicken
anyone have a pic of the hurst shifter w/ a hurst pistol grip shift handle on it?
http://www.jegs.com/webapp/wcs/store...52621_-1_10521
Old May 24, 2007 | 05:38 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Probinator, if he's good its worth the drive from L.A. Id appreciate his info.
Old May 24, 2007 | 09:35 AM
spuddogg's Avatar
spuddogg
ORIGINAL: EmperorOfChicken
I took it off several months and went back to the white queue ball.
[IMG]local://upfiles/43315/E7535F2BD1064FE5AF18922AF5E3BDFB.jpg[/IMG]
Old May 24, 2007 | 09:39 AM
lieu910's Avatar
lieu910
I just ordered a H/S.
I have not had any problems, nor do I have any real complaints on the the stock shifter either. I've never missed a gear, but those that have had that problem seem to be equally frustrated with the Hurst in that regard.
The Hurst is perhaps an improvement over the stock shifter, but ifyou're looking for the best shifter out there in terms of action, precision, adjustability, look into the MGW.
Old Jul 12, 2007 | 02:08 PM
teksp0rt's Avatar
teksp0rt
So did you get the shifter installed?
How hard was it... I am going to attempt it next weekend.
I am ok with tools but, am scared $hitless of messing up the car...
Old Jul 12, 2007 | 09:27 PM
D_Gusler's Avatar
D_Gusler
