Doing Duplicolor Caliper Today....any tips?
Old May 26, 2007 | 02:10 PM
nonstopred's Avatar
nonstopred
Default Doing Duplicolor Caliper Today....any tips?
Is there any tips I should be aware of while im doing this? Like how many coats? How thick each coat? How long in between? Should I work on other wheels while the others are drying?
Anything else anyone wants to shoot out there would be a great help. Thanx
Old May 26, 2007 | 02:14 PM
TPony's Avatar
TPony
Default RE: Doing Duplicolor Caliper Today....any tips?
I also used duplicolor....I had two coats on...wait about 1 hr between coats and go for it..it's pretty straight forward. Ensure you use the brake cleaner solution, to clean the calipers. I did not mask anything, but it may be a good idea. The caliper cleaning solution is pretty strong. One more thing, paint in a very well ventilated area or you'll have an unintended high.....
Old May 26, 2007 | 02:19 PM
nonstopred's Avatar
nonstopred
did you not mask just for the cleaner? orfor the paint as well?
Did you guys paint the entire caliper? or just the upper part and not the lower lip. Thanx
Old May 26, 2007 | 03:21 PM
lldsandsll's Avatar
lldsandsll
i used duplicolor engine enamel and engine degreaser and hot soap water to clean. two or three coats, 5 or 10 minutes between coats. the spray dries enough for a second coat pretty quick. after about 15 min on the final coat i CAREFULLY remounted the wheel and moved on. i did it one wheel at a time. i didnt paint the entire calliper, just as much as possible. i wrapped each rotor w/ newspaper, and taped it down to leave just the calliper exposed.
dont forget to go to xenonmods.com to get your calliper decals!
Old May 26, 2007 | 03:41 PM
philster2003's Avatar
philster2003
I just did mine last night and it took like 2.5 hrs to do all 4 calipers including applying the Pony decal. I really took my time, no tape used and I had a few small fine brushes I used instead of the inadequate brush they supply. Look for yourself, it really is a no brain-er.
Old May 26, 2007 | 04:27 PM
lldsandsll's Avatar
lldsandsll
looks awesome! u should put the "mustang" above the pony.
Old May 26, 2007 | 05:20 PM
nonstopred's Avatar
nonstopred
you think i'll be able to add a decal in the future if I want to? Because I dont want to wait for one to get shipped, and I want to do them ASAP.
Old May 26, 2007 | 08:31 PM
lldsandsll's Avatar
lldsandsll
ya, u just might have to carefully wash ur calliper surface before applying. it'll work fine tho.
FivePointToTheOh
Mar 9, 2020 10:26 PM
mdj89
Sep 23, 2015 08:49 AM
maestro1024
Sep 21, 2015 02:40 PM
Sep 10, 2015 08:39 PM
