on car balacing?
on car balacing?
Does anybody know of a shop that can perform on car balancing ( where they balance your tires while still on the car) in los angeles or san fernando valley. the shop i go to in pasadena will be down for a couple of weeks. thanks in advance
RE: on car balacing?
Theres a place about 2 miles from my house that does it. I think that is the best kind of balancing, not only does it balance the rim and tire but it balances everything that rotates to ensure a good balance. I had it done once on a previous car and the car rode smooth as glass afterwards. Whenever I'm in need for balancing again thats what I'm gonna do.
It is the best way to balance front wheels because all the rotating mass is balanced as a single unit. Just like balancing a crankshaft and flywheel as a unit. Cost is not bad. But if you rotate your tires on a regular interval, it can get pricey as you will have to do it again once the rear wheels are switched to the front.
Sounds like a waste of money to me. Ive never had an issue balancing my tires. 140+ smooth as glass.
Alot has to do with the operator of the machine. I like to balance mine to the 100th of an oz. tho. Having a machine to do it helps
Using a machine that does road force balancing and match mount balancing, and a pin plate to mount it on the machine helps alot also.
Most balancers use a cone thru the center hub. Well the wheel is held on by the studs/nuts to the car, why not balance it the same way it mounts to the car.
My .02 and experience.
GTStang can back me up since he works at Discount Tire, but they have a new machine that will basically do that I believe. I just had tires mounted last week there and they did whats known as computer ride matching....They simulate a load on the tire to properly mount and balance it. I could be wrong but that is what was explained to me.
ORIGINAL: howarmat
The quality of the balance machine and the operator has everthing to do with getting good results, find a shop that specializes insuspension work, preferably a shop that works on race cars.Don't just take itto a cheapo tire shop. Basically, You always get what you pay for. Make sure thier machine is a "Road Force Balancer"
