18X9.5 Wheels and 255-45-18 Tires?
All,
I was thinking of gettting the 18" SVT 2007 Cobra wheels at Tire Rack. They are 9.5 inches wide.
TR recommends 255-45-18 tires. I'm doing the same size on all 4 corners. I was concerned that this tire size will look a little stretched on those rims. I think that wheel/tire combination is the one on the front of the GT500, but I've been wrong before :-). I don't do any racing or dragging. Just some spirited fun.
Anyone have comments on this setup?
Thanks,
ckam888
Thanks,
ckam888
RE: 18X9.5 Wheels and 255-45-18 Tires?
ckam888,
The quoted tire size is stock for the GT 500 front tires and the rears are 285/40/18. The 255’s are about as narrow as I would want to go on the front with the 18x9.5 wheel, and the 285’s are about as wide as I would want to go with the 18x9.5 wheel. Others may have something else to say, but my personal experience is stated above. I have the BFG KDW (II) tires and so far I am happy with them, although I sometimes wish I had purchased the BFG Drag Radials for the rear. I might get a set of the GT 500 wheels and BFG Drag Radials for the track. We’ll see.
Check out this thread for more info: https://mustangforums.com/m_2960427/...tm.htm#3346574
I have 255/45s on my 9.5" wide wheels on my Mustang. They fit ok, but could probably be a touch wider, honestly. I wasn't sure about any possible rubbing up front when turning sharp, though, so I decided to stick with 255/45.
FWIW, I have 295/45 wide tires on 9.5" rims on the rears of my Marauder and they fit just fine. They are Nittos, though, and I understand that they run a touch narrow compared to other brands. But, I think you could get by with 295s on a 9.5" wide wheel ok. Probably need a 10" wide wheel for anything bigger, though.
Galactic
04-29-2019 02:56 PM
09-08-2015 11:50 AM
