Negative Camber Problems
Old Jun 8, 2007 | 06:50 PM
06blackonblack's Avatar
06blackonblack
Default Negative Camber Problems
I had my 2006 GT lowered with the Eibach Pro-Kit about three weeks ago. At the time the shop that did the installation told me that my car had a negative camber problem (inside of front tires wearing out more rapidly than normal). They installed a camber kit and did an alignment after they installed the springs but suggested that I buy new front tires (about $350). I have about 20,000 miles on these tires, Falken Azenis 245/35/20. Has anyone had the same issues with the front tires having negative camber problems and what didyou do to fix the problem? Did you have to buy new tires? Any advice? Thanks.
Old Jun 8, 2007 | 07:44 PM
RodeoFlyer's Avatar
RodeoFlyer
Default RE: Negative Camber Problems
I'm confused - you say they installed a "camber kit". The problem is solved now correct?
Old Jun 8, 2007 | 07:56 PM
moosestang's Avatar
moosestang
Ummmmm, same question.
ORIGINAL: RodeoFlyer
Old Jun 8, 2007 | 08:26 PM
157dB's Avatar
157dB
Cut & Paste Expert
+1
Old Jun 8, 2007 | 09:01 PM
hottymustang's Avatar
hottymustang
I think that he means to ask the question " Have you guys had this problem with negative camber on your car, and had the alignment shop tell you that you need new tires?"
Question - How long was the time between the shop installing the springs and doing the alignment? Because if they did it all in the same day (which is as it should be) then this wouldn't have been an issue. And if the shop that did the install knew that you had negative camber and didn't tell you that you should have it aligned is a little weird.
My answer - No. As soon as we lowered my car I took it to the local shop and had it dialed in perfect. So I don't have negative camber at all, and my tires never wore funny.
Old Jun 8, 2007 | 09:59 PM
06blackonblack
The shop lowered the car and did the alignment the same day. They noticed the negative camber the day they did the installand saidthe tires were damaged and I needed to replace them.
And yeah my question was basically if anyone had to replace their tires because of negative camber after basically one year of use.
vargas
Jun 17, 2017 12:17 PM
guitarman376
Oct 11, 2015 01:47 AM
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
RWHEELS
Sep 5, 2015 03:42 PM
