Passenger side rattle
For the last couple of weeks I have had a rattling noise coming from the front passenger side of the car. It sounded like something hitting metal lightly. I could not find anything loose under the dash or passenger kick panel. The passenger A-pillar was also tight so I though a rock might be behind the inner fender on the passenger side. I took it off and no rock. What I did find was the antenna cable had a lot of slack in it and when I bumped it against the metal I found the rattling I was hearing inside the car. I fixed it by taping the excess cable to the side of the fender. Problem fixed! I suppose you could also pull the excess back through the firewall and zip tie it up under the dash. Anyways just thought I share this in case anyone else has a rattle they can’t find.
[align=left] [/align]
