Sequentials! <--- Update & Installed!
Old Jun 18, 2007 | 12:42 PM
JudisStang's Avatar
JudisStang
Default Sequentials! <--- Update & Installed!
It is finally done and they look AWESOME!
This is the kit I bought: http://www.classicdesignconcepts.com...splay/635.html
Before the purchase:
CDC's email customer service person, Paul was excellent and responded to my question in 1 day. My only hesitation was if I had to remove the shaker1000 subwoofer to install the sequentials and the answer is truly NO but in my opinion, it would be MUCH easier if you are able to.
(note to ford: how the hell am I supposed to change the light bulbs with the subwoofer so close to the taillight housing???)
The installation took about a total of 1 hour with the help of my brother and husband (who handed me the tools and tightened the nuts that I couldn't)
General instructions to see if you are up to it:
Remove the plastic covering inside the trunk that covers the taillight housing.
Remove the rug and rug pieces.
Use an 11 socket (wrench on the right) to unscrew the bolts that hold the taillights in - there are 3 on each side. (right side is the pain).
Unclip harness and Remove taillight - switch out factory harness & bulbs with CDC harness and repeat on other side.
Plug both in and have someone test them out, the reverse/flashers and blinkers/brake...
Place everything back together!
Thanks Scott and Garry for your help! LOVE THEM!
Old Jun 18, 2007 | 12:53 PM
FlaPony's Avatar
FlaPony
Default RE: Sequentials! <--- Update & Installed!
Great mod...I love mine. I find I use the turn signals more than I used to. Too bad we can see then though. I look in the rear view and see people pointing at my tail lights all the time.[8D]
Old Jun 18, 2007 | 01:19 PM
157dB's Avatar
157dB
Cut & Paste Expert
What is the year of your stang? They are quite different between the
05, 06 and 07 in respect to the taillight wiring. Round or Flat where
the wires go thru the sheetmetal? Which Dynamite Stick kit did you
use and for what year model/wire style was it? More info please.[8D]
Old Jun 18, 2007 | 01:32 PM
JudisStang's Avatar
JudisStang
hi 157 - the link above is the exact harness i purchased. my GT is an 07...
It says it fits 05-07, but before you order, email CDC to verify... the earlier years (before 05) have a sep. harness/lights
from the CDC website:
OUR Prices and Applications:
$149.00 -- 110631 - 2005-7 Sequential Taillights
and there is a round rubber piece in my 07 through the sheet metal, not flat...
if i can help with anything else, let me know...
Old Jun 18, 2007 | 01:36 PM
JudisStang's Avatar
JudisStang
Thanks Fla! I told my husband, go drive around so I can follow you and see what they look like LOL
Too bad we can't see them, but seeing them on a GO in lyndhurst near my house made me purchase them - they looked AWESOME and I had to have them!!!
Old Jun 18, 2007 | 03:37 PM
Drop Top 06's Avatar
Drop Top 06
welcome to the cool club!
Old Jun 25, 2007 | 06:45 PM
157dB's Avatar
157dB
Cut & Paste Expert
www.meter4it.com
Better sequentials for the same $$ as CDCs.
http://www.meter4it.com/2006_and_2007_Mustang.htm
Old Jun 25, 2007 | 06:52 PM
PennState's Avatar
PennState
Old Jun 25, 2007 | 07:00 PM
Lito's Avatar
Lito
I got mine from webelectric, splice kit 69$. Took me a little longer cause I wanted it soldered.
Old Jun 25, 2007 | 08:06 PM
157dB's Avatar
157dB
Cut & Paste Expert
Soldered is the only way to go.
Those scorch lock insulation displacement
connectors are c double r ap.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
amandahchase
Sep 3, 2015 10:09 AM
