Driveway help!
Old Jun 20, 2007 | 05:16 PM
hammeron's Avatar
hammeron
Default RE: Driveway help!
ok......you can buy rubber mats that measure
approximately 16" wide 24" long and come
in various thicknesses. i usually deal with the
1/2" thick type.
these you can lay out for extended periods of
time and when you feel like cleaning up the area
for the street sweeper, they can easily be picked up
and thrown into the garage.
they are also easily cut into various shapes
ORIGINAL: WonderStang
Need some ideas here...
I lowered my mustang but now it can't get up the sidewalk into the driveway without hitting the concrete. Anyone having any ideas about ramps or whatever? Not sure the city would like it if I changed the sidewalk!
Thanks!
Old Jun 20, 2007 | 05:22 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
+1 Use rubber welcome mats
Old Jun 20, 2007 | 05:40 PM
157dB's Avatar
157dB
Cut & Paste Expert
Pour some concrete to fill the void that
is between the curb and driveway.
Old Jun 20, 2007 | 06:16 PM
wthalliii's Avatar
wthalliii
http://www.guzer.com/videos/jumping_car_breaks.php
Sorry, couldn't resist...
Old Jun 20, 2007 | 06:25 PM
Ghettobooty's Avatar
Ghettobooty
air ride suspension tech set up with installation will probably be around $5000 and the arnott is about $3100 just for the kit alone. i've read excellent reviews for the air ride tech suspension, especially for handling. i think it's the only air bag set up that currently focuses on ride/handling. the rest of the systems sacrifice.
good luck
ORIGINAL: wingman75
Adj. Air Suspension. Raise and lower to whatever is needed. They do have a setup for Mustangs.
Old Jun 20, 2007 | 07:16 PM
blaven's Avatar
blaven
I only did the roush rears and my little driveway that leads into my garage scraps my cdc chin. But i had some left over carpeting that i cut apart to sit underneath where it was touching which was maybe only about 3 inches almost dead center of the chin spoiler. 1st time i did it it barely hit, 2nd time took a little bit of paint off from the underside which i just touched up. Haven't had a chance to try the carpet since it happened but at least it won't be scraping on the bare driveway now.
Old Jun 20, 2007 | 07:42 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: blaven
Can I see some pics of this Roush only rears. Were they easy to install or did you have someone
do it for you? I got theRoush rears but have not installed them yet as I am awaiting poly sway
bar bushings to install at the same time. Do you like the Roush rears. Did they drop you 3/4" as
advertised?
Old Jun 20, 2007 | 08:03 PM
gatkins94's Avatar
gatkins94
Maybe this is too simple....can you come at it at an angle? If not....the only way will be something to drive over.
Old Jun 20, 2007 | 08:55 PM
allj's Avatar
allj
I tried the angle with mine. No luck. [sm=sigh.gif]
Old Jun 21, 2007 | 11:10 AM
jerjan's Avatar
jerjan
I like the jumping car vid, I liked the way it beat itself to death!
ORIGINAL: wthalliii
