need to know if these would fit...please help
RE: need to know if these would fit...please help
what if they were 18s???
would that change the required offset???
I'm also planning on lowering the car about 1' in front and 1 1/2-2' in the rear.
what would be the best setup?
19x8 +40 offset F
19x10 +40 offset R
or
18x8 +40 offset F
18x10 +40 offset R
19x8 +40 offset F
19x10 +40 offset R
or
18x8 +40 offset F
18x10 +40 offset R
The fronts will fit fine. For the rear, measure your distance from the stock wheel mounted on the car to the closest object behind it (spring). If you have at least 1" clearance, you'll should be OK.
