Heat From Console?
Old Jun 27, 2007 | 11:15 AM
LesteR723's Avatar
LesteR723
Default Heat From Console?
this has been happeneing more and more as it gets warmer outside, just as it did last year. When my cars motor warms up, if my A/C is off it will spew hot air through my vents (top and bottom) as well as under the dash and console where the tranny tunnel is. Does everyones car do this or is this just something that i have to get used to?
Old Jun 27, 2007 | 11:21 AM
mightymouse's Avatar
mightymouse
Default RE: Heat From Console?
mine does the same thing with no A/C on and the trany hump gets hot because the cats sit right below it.
Old Jun 28, 2007 | 02:46 AM
LesteR723's Avatar
LesteR723
so... no fix?
Old Jun 28, 2007 | 02:28 PM
CLUBSFIT's Avatar
CLUBSFIT
I dynomatted the whole inside of my tunnel, and no heat, also helped w/noise from the drivetrain! then I stuffed the rest of the tunnel w/pillow stuffing. Wala all good. Sounds ghetto, but cant see a thing.
Old Jun 29, 2007 | 11:55 PM
LesteR723's Avatar
LesteR723
did you have to take out pretty much the whole console and radio/HVAC/ etc etc to get under the carpet? did it all go back together right? how long did it take you and how much did it cost for all that?
Old Jun 30, 2007 | 01:52 AM
jerjan's Avatar
jerjan
All vehicles are required to have a fresh flow of air, they are not allowed to be air tight, I believe the main reason is because of carbon monoxide that could possibly build up in the passenger compartment. Years ago they called it flow through ventillation. That could explain the air flow in through the vents. Having heat flowing through the console could well be another problem. A lot of people insulate the tunnel area to help prevent heat ingress around the shifter boot.
Old Jun 30, 2007 | 05:31 AM
Diabolical!'s Avatar
Diabolical!
Have you ever been under the car? Ford mounted the damn cats so far up that you can cook a turkey in the center console compartment.
Old Jun 30, 2007 | 12:12 PM
LesteR723's Avatar
LesteR723
ORIGINAL: jerjan
mines an auto, so no shifter boot heat. I also knew that cars weren't air tight, but damn someone must have hooked up the heater core to the fresh air flow system cause its generally hotter than the already boiling summer air. Terrible design
ORIGINAL: nineinchnail1024
Yes i have, countless times, and i saw that as well---just um, never really made the connection lol
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
