Help with removing this take a look.
RE: Help with removing this take a look.
looks like it is probably just held on by double sided tape. I would try some simple things first such as soaking it with wd40 or goo gone. These both help eat away at the "stickyness" of the tape. I wouldnt reccomend using any sharp objects as you will more than likely scratch the paint. Once you spray the trim peices just try pulling on them and then soak it some more. It may take some time but eventually it will come off. You could also use a heat gun or hair dryer on a low setting to try and loosen the tape. Remember though, rewax anywhere the solvents got, and where the tape used to be. Hope this helps
Heat is the trick. Take a hair dryer, hold it over the end of the piece on the low setting for several minutes. You should then be able to pry up the end of the trim with your fingers. After you get the end off, you should be able to peel it back slowly while applying the heat. My son just did this on his Cougar and it worked like a charm.
Don't be afraid, the heat won't hurt your paint.
UB10
UB10
ORIGINAL: underbird10
UB10
UB10
