BIG PROBLEM!!!
Old Jun 29, 2007 | 06:08 PM
TrIpOd's Avatar
TrIpOd
Default RE: BIG PROBLEM!!!
ORIGINAL: thedrod
If you go turbo I would keep the 3.55s.
Supercharger I would go with 4.10s.
im going turbo and already have 4.10s installed??
Old Jun 29, 2007 | 06:12 PM
moosestang's Avatar
moosestang
Wouldn't that be the other way around?
ORIGINAL: thedrod
Old Jun 29, 2007 | 06:15 PM
TrIpOd's Avatar
TrIpOd
im bad with tires. what would make the right ratio around 3.83. a 255/55/18 all around?
Old Jun 29, 2007 | 06:18 PM
moosestang's Avatar
moosestang
The kdw2? If so then no. I like the look of those tires (look like flames), but their available sizes suck ***, nothing but ricer sizes in 17[:'(]. Unfortunately those of us that like a tall tire on the rear are screwed by todays tire manufacturers. You'd have to go with a high performance tire meant for a sport truck.
ORIGINAL: TrIpOd
are there bfg kdws in that size?
Old Jun 29, 2007 | 06:21 PM
TrIpOd's Avatar
TrIpOd
ORIGINAL: moosestang
ORIGINAL: TrIpOd
what size would it be if I wanted 255s all around?
moosestang's Avatar
moosestang
There are many tire size calculator online that will spit out the overall diameter for you. A 255/55/18 is right around 29 inches tall and there are quite a few to choose from on tirerack.com. Great place to buy from by the way, i've bought 3 sets from them so far. (not all this car)
http://www.tirerack.com/tires/Compar...;x=52&y=10
ORIGINAL: TrIpOd
Old Jun 29, 2007 | 06:23 PM
moosestang's Avatar
moosestang
ORIGINAL: TrIpOd
http://www.miata.net/garage/tirecalcold.html
Old Jun 29, 2007 | 06:24 PM
TrIpOd's Avatar
TrIpOd
thanks for your help moosestang!!
Old Jun 29, 2007 | 06:32 PM
TrIpOd's Avatar
TrIpOd
one more question. what ratio would i put on my tuner to fix my speedoif my ratio is 3.83?
Old Jun 29, 2007 | 06:33 PM
moosestang's Avatar
moosestang
ORIGINAL: TrIpOd
If you are lowered I don't think a 29 inch tall tire in the front will work. Even if you're not lowered I would check around to see if anyone is running a tire that tall in the front.
