BIG PROBLEM!!!
Old Jun 29, 2007 | 06:34 PM
  #21
moosestang's Avatar
moosestang
Default RE: BIG PROBLEM!!!
You'd leave it at 4.10 and change the rev's per mile or whatever it's called. That will correct your speedo for you.
That tire size calculator give you the revs/miles for you, but double check with some other calculators first as i'm not sure how accurate that one is.
ORIGINAL: TrIpOd
one more question. what ratio would i put on my tuner to fix my speedoif my ratio is 3.83?
Old Jun 29, 2007 | 06:50 PM
  #22
TrIpOd's Avatar
TrIpOd
what do you think about these tires eagle f1 in 255/55/18
http://www.tirerack.com/tires/tires....cleSearch=true
Old Jul 2, 2007 | 01:43 PM
  #23
thedrod's Avatar
thedrod
ORIGINAL: moosestang
Wouldn't that be the other way around?
ORIGINAL: thedrod
If you go turbo I would keep the 3.55s.
Supercharger I would go with 4.10s.
Turbos need more room to rev. A set of 4.10s decreases that. Also turbos make more power than superchagers up high, which will make traction even more of an issue with 4.10s.
One of my clients turbo06 will go sideways on the freeway at 60mph with 4.10s, then bounces off the rev-limiter and goes nowhere. It's just geared too low for the boost surge around 3200rpm.
Old Jul 21, 2007 | 11:55 AM
  #24
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
tripod learn how to use google and the search button
Old Jul 21, 2007 | 12:24 PM
  #25
newagemuscle's Avatar
newagemuscle
ORIGINAL: TrIpOd
alright guys, i had my 4.10s installed about a month ago telling myself I'm not going to get any type of forced induction. well... i changed my mind and decided to order a turbo. is there any way to keep tiresthese from spinning through gears? i would hate to have to spend another 550 on 3.73s. ive talked to a few people on this site an they've said 4.10s and FI isn't that bad. although, at the track with sticky tires ill see some nice times but this is a daily driver. any suggestions?
My buddy is running 17 psi with his vortech and is methane injected also. He put down 520 to the wheels and is also running a 4:10. Because of the profile tire he is running its more like running a 4:30 in his car. He spent around250 bucksper wheel and had the rears widend to fit a 315 BF drag. When I drove the car it seemed to hook preety darn good on the street. He was also able to pull mid 11 sec times with the set up at close to 127mph. By the way the wheels do not stick out either.
Old Jul 21, 2007 | 01:07 PM
  #26
TrIpOd's Avatar
TrIpOd
ORIGINAL: oshkoshbajawsh
yeah ok newb, at least im not lying about my rwhp douche bag
and thanks for bringing up an old post just to insult me. it really shows your ignorance
Old Jul 21, 2007 | 01:38 PM
  #27
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Try it out with the 4.10's and them evaluate the situation. No point worrying about it now
Old Jul 21, 2007 | 01:48 PM
  #28
Bluestar's Avatar
Bluestar
+1 try it as is, but if it's your DD like you say it might be a little tricky on wet roads. IMO 3.73's would be the way to go.
jma2
Jul 10, 2023 01:00 AM
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
MasterLanMan
Sep 13, 2015 08:21 PM
DoctorScary
Sep 9, 2015 07:53 AM
