SCT ADJUSTING STALL
Old Jul 9, 2007 | 06:00 PM
GTJUNKIE's Avatar
GTJUNKIE
Default SCT ADJUSTING STALL
Can the sct tuner adjust my stall speed. I'm running stock auto tranny with stock converter I was reading some posts and ran across one that said he adjusted the stall speed. If so would that allow me not to buy a new torque converter?
Old Jul 9, 2007 | 06:44 PM
scrming's Avatar
scrming
Default RE: SCT ADJUSTING STALL
ORIGINAL: GTJUNKIE
No... No tuner is going to be able to do that... The Torque Converter Lockup can be adjusted. (though you will probably need to talk to your tuner...) In the old extreme tune software there was a section for lockup....
Old Jul 9, 2007 | 07:32 PM
drbobvs's Avatar
drbobvs
+1, lockup only I believe.
Old Jul 10, 2007 | 06:11 PM
GTJUNKIE's Avatar
GTJUNKIE
Can someone explain what the lock-up is and what it does?
Old Jul 10, 2007 | 07:00 PM
hammeron's Avatar
hammeron
http://www.familycar.com/Transmission.htm
http://en.wikipedia.org/wiki/Torque_converter
it's a good read
Old Jul 10, 2007 | 07:27 PM
06tyrfryr's Avatar
06tyrfryr
your tourqe converter goes into lockup in fourth and fifth gearduring part throttle and eliminates slippage of your tourqe converter by going into the lockup mode and helps increase fuel mileage by being basically like a direct drive like a manual trans would be
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
winner99
Sep 30, 2015 07:04 PM
