Problematic fuel pressure regulator on 2005?
Anyone had any trouble with their fuel pressure regulator. I have been running up against hard starts and had the battery alternator fuel pump checked. So far they have not found a problem. I read an article about how the fuel press. reg. can make it difficult to start. I haven't had that checked yet and seems simple enough, just wondering if anyone else had some input. Thanks.
RE: Problematic fuel pressure regulator on 2005?
since it might be a fuel related issue, you might take
a look at the fuel filter, just to make sure everything
is fine, then move on to the regulator
also, make sure there is no problem with the fuel pressure
sensor vacuum line (on driver side fuel rail).
[IMG]local://upfiles/37808/43B5EA82529F4DDFA00A894E4BF32E4C.jpg[/IMG]
[IMG]local://upfiles/37808/DCA0E93B99D543B2A2EFD5AF882E62BF.jpg[/IMG]
foxtrot
09-29-2015 06:32 AM
