wheel sizing chart for S197
Does one exist somewhere that gives acceptable offsets based on different widths.
For example i'm trying to find out if I can get a 18x9.5 with 20mm offset to work all the way around my 05.
I'm searching but little luck with our current search engine
I don't know about a sizing chart, but i think those rims will stick out almost 1 1/2 inches compared to the stock wheels. First they are 1 inch wider, so 1/2 inch further in and out than stock, then 25mm less of an offset which is a full inch. It will look like an old 90 something camaro with the wrong rims on it.If you want an 18x9.5 then you should be looking for close to the stock offset or closer, close would be 36mm.
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
