Strange electronic issues
Old Jul 17, 2007 | 05:02 PM
jdt141's Avatar
jdt141
Default Strange electronic issues
I'm getting some "demons" in my 07 GT, and wondered if anyone else had similar problems....
The volume on the radio randomly turned DOWN today...(i do not have the shaker 500 or 1000, just base stereo) usually the speed sensitive sound only goes up...
and my "auto down" feature on the driver's side window doesn't always work. i hit both the driver and passenger side buttons simultaneously, and the driver's side signal doesn't latch and continue to open. (50% of the time)
if anyone has a clue, i'd appreciate it before i took it to the dealer, as these issues will undoubtebly not be found by the service techs. thx!
Old Jul 17, 2007 | 05:23 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Strange electronic issues
Do you have the dreaded passengers side
water leak? Is your carpet wet over there?
The SJB is probably getting wet from the
unadvertised under dash water dispenser.
Leaky Stangs are a well known problem.[:@]
Old Jul 17, 2007 | 06:25 PM
jdt141's Avatar
jdt141
ORIGINAL: 157db
i haven't noticed, but i haven't looked.... the SJB is what exactly?
Old Jul 17, 2007 | 06:57 PM
05gtdriver's Avatar
05gtdriver
Wow, too coincidental! On my way home from work today, after warming up the GT, I raise the volume on the Shaker 500 and the sound quality is all gargled and sounds muffled(?!?). I turn the stereo off and turn it back on and it disappears(hmmmm?) and sounds normal. Never had that happen before in either of the GTs I've owned('05 & now '06), or any other car I've owned. Very bizarre indeed........
Old Jul 17, 2007 | 07:04 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: 05gtdriver
Same thing happened to mine once. Contributed to my decision to dump the Skipper 500, and I never looked back.....No SJB leak here. As far as the windows, check your owners manual, and do the steps to re-program the windows. If that does not solve the issue, dealer time!!
Mike
Old Jul 17, 2007 | 07:09 PM
157dB's Avatar
157dB
Cut & Paste Expert
SJB = Smart Junction Box
Passengers side under the kick panel.
Remove the door sill and kick panel
and get under the carpet to the pad.
Is it wet? Moldy smell?
Old Jul 17, 2007 | 07:31 PM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: 157db
Yep that was my first thought as well.
Richard
Old Jul 17, 2007 | 10:03 PM
doode's Avatar
doode
for the window, with you in the car, door fully closed, pull the window switches up and HOLD for 3-5 seconds
you will hear a click. its the window travel resetting itself and you will get full auto up and down function
i hope its something as simple as that and not the SJB
Old Jul 18, 2007 | 11:04 AM
fredlo69's Avatar
fredlo69
Sound like the passenger kick panel leak. It happened to me during a down fall of stormy rain, all gauges were out of whack and stereo was acting up. Had to disconnect my battery for a few minutes and re install. Every thing was back to normal. I checked the rug and it was wet. I took it to these bastards of a dealers and they can't find the source of the leak. This weekend I'll be checking another dealer.Very upset with fords quality and their dealers. Also dealing with the thunking noise up front.The dealer said it was a loose stabilizer link and the tightened it. Bull sh*t. Man so disappointed with this car,thinking hard about trading it in for anything other an American car.
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
