New GT, Break in period and mods??
My 2008 GT is supposed to be here in about two weeks. I already have the FRPP cold air intake/tuner, and some borla stinger cat-backs sitting in my garage. My question is, should I break the engine in before I put these mods on or is it ok to install them as soon as I have the car? Also what is the best way to break in these new engines? The last new vehicle I got was an 05 F150 and I just drove the hell out of it right from the start. I want to be a little more careful with my (actually the wife's) Stang! Thanks for any input.
RE: New GT, Break in period and mods??
No break-in needed, drive the snot outta it!
If it were me, I'd at least wait a bit till adding on the CAI and exhaust, to better appreciate the difference. But I don't see why you shouldn't be able to add them right off the bat.
Remember it's not just the engine, you have to break in gears, brake rotors, pads etc. Allow your car some 1000 miles of driving at different speeds, it is a small sacrifice at least worth if you intend to have your car for a long time.
I'd wait 1k miles and a month before installing any mod, this period will let you test your car and make sure everything is ok, if your car comes with some problem from the factory how do you intend to make a claim to the dealerif it was already modified. this is just my opinion.
Good luck and enjoy your new ride
Drive the car for at least 300 Miles, Change the oil and filter. A new engine will clean off the bearing surfaces 10,000 th or so of the surface, and deposit that in the oil. Also there will be piston ring to cylinder wall initial scrubbing. After the oil change , drive it like you want. But don't stand on it hard until that crap in the oil is gone. You filter should trap it all, but when you stand on it, sometimes, The oil system goes into Filter bypass, cause the filter can't keep up with the oil needed. When you have clean oil in there that condition wont really matter.
after the car's at normal op temp, just vary engine speeds during driving so when you do feel comfortable beating on it (mileage-wise), the engine has been run at the higher rpms and won't go into "shock"...
p.s. that FRPP CAI/tuner is one of the most expensive and lowest gain-yielding setups out there...not trying to be mean or anything...is it too late for you to go a different route with that?
The owners manual say it dosnt need an exxesive break in, i would go easy for the first 1000 miles. as far as modding it it dosnt matter.I had alot of my mods before i even had the car. Brought it home from my work (the dealer) next morning started the installs. Have Fun with it man
ORIGINAL: s197richie
Thanks for the input.
^^^I'd go C&L street/sct tuner combo from brenspeed if you're manual, or a similar setup from bamachips if you're auto...re: the s/c comment, remember these engines have cast rotating assy's and have a rather low "danger zone" (around 420 hp) without swapping to forged internals, not to mentionwhat the clutch and trans are rated at...but anyway, yeah bren or bama for the combo makes for an excellent first mod...unless the warranty issue is stressing you, short gears, sticky rubber and some rear ca's would really make you smile more...hope this was helpful...
I took it easy for 1000 miles, then changed the oil. I waiting till almost 10k miles to start modding because I wanted to be sure there were no mechanical problems.
