BFG Drag Radials
BFG Drag Radials
I am stuck at 13.9s in the 1/4 on my 19" rims and Pirellis. I am considering the BFG G Force drag radials. Who has these and what are you opinions? I was also looking the Mickey Thompson ET Street deal at Brenspeed but I don't like the idea of driving to and from the track (30miles each way) with radials on the front and Bias on the back, That's an accident waiting to happen. I also don't want to change the tires at the track. These tires will be removed the day after racing so I won't be driving every day on them.
Any opinions or suggestions would be appreciated.
RE: BFG Drag Radials
I do in fact have them.....
265/40/18 on the stock 18" bullits... I have not tested them really hard yet... but in the minor stuff I've done... the hooked well.
drop form 4th to 2nd @ 45ish... just a chirp and go.... from a dig... quick clutch slip at 2500 ish... a little chrip and go....
but they are not made in 19".... 14/15/17/18 only... so u'll get another rim set for them? if you do 15/17 probably best with a tall tire with big sidewall for you launch!
It appears summit racing has them.
http://store.summitracing.com/egnsea...=KeywordSearch
ORIGINAL: 06VistaBlueGT
Yeah, I've got the original 17's Was going to put 275/40 17 on em.
and that size is a bit big for a 8" rim.... but if your not using them as a DD mabye you could get away with it...
Minimum rim width recommendation is 8 1/2 but they won't be used as DD tires. I figured if I deflated them a little more than normal I'd counteract the bow in the tread from a small rim.
