Unusuall Offset? ???
Old Aug 7, 2007 | 01:43 PM
Sherwood06GT's Avatar
Sherwood06GT
Default RE: Unusuall Offset? ???
295x45x18 rear, and 275/45/18 front. Nitto's!
Old Aug 7, 2007 | 01:46 PM
Mustangansta's Avatar
Mustangansta
wow such wide tires up front are ok ? - i dont want to change brands since i already have the new sumitomos thats why im only lookin for 2 - trying to work my way round this
Old Aug 7, 2007 | 02:04 PM
Sherwood06GT
ORIGINAL: Mustangansta
https://mustangforums.com/m_1569917/tm.htm
Old Aug 7, 2007 | 02:10 PM
moosestang's Avatar
moosestang
Well I don't think i'd want to go with a shorter diameter in front to match the back. Even if you lower it, it will still not look as low as a car with stock diameter tires, but you will be closer to the ground which wouldn't be good imo.
You could change to a 275/40/18 in the back (26.7 inches tall)which would be .8 inches taller than the tires you have now and only .3 inches shorter than your fronts. You shouldn't notice a .3 inch difference.
If you want to keep the back and have a front that is about the same size in the sumitomo, get a 245/40/18. That would be 25.7 inches tall and your current rear tires are 25.9 inches tall.
If you go that route just be carefull if you lower it because you'll be 1/2 inch closer to the ground than any mustang running stock height tires.
Old Aug 7, 2007 | 02:21 PM
Mustangansta
amazing input guys - thanks a bunch for putting up with this - --
? when you say closer to ground and be careful - your concern is scrapping driveways and such or actual handling performance - the later is what i can not deal with
gagemcc
Sep 22, 2015 09:43 AM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
chain1
Aug 19, 2015 09:04 AM
96MustangGT
Aug 5, 2003 02:53 AM
