computer swap
Old Jul 25, 2007 | 04:56 PM
lldsandsll's Avatar
lldsandsll
Default computer swap
i thought this was rather interesting:
a friend of mine was having problems with his car and was told it was his computer (PCM), so we decided to swap out and see what would happen. neither car would start with the other car's computer in it. just puttin the info out there.
Old Jul 25, 2007 | 04:58 PM
hammeron's Avatar
hammeron
Default RE: computer swap
that is good to know actually
Old Jul 26, 2007 | 09:05 AM
SCCAGT's Avatar
SCCAGT
Neither car would start because the ecu and keys are not coded to each other.
Old Jul 26, 2007 | 09:41 AM
ohnoesaz's Avatar
ohnoesaz
So what happens if your ECU goes bad and you buy another one online or something? Does this mean the dealer has to get involved?
Old Jul 26, 2007 | 09:52 AM
howarmat's Avatar
howarmat
s197 Junkie
ORIGINAL: ohnoesaz
Yes the dealer will have to be involved in this time of problem...
Old Jul 26, 2007 | 11:07 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: SCCAGT
Swapin PCMs. WOW. I would be afraid of
mine not working after being in his non-starting PCM
blowing Stang.....[:'(]
I stand corrected.
Old Jul 26, 2007 | 12:21 PM
bascho's Avatar
bascho
It's scary that some of you even respond on this subject.
First off.......computer? What do you mean by this? The engine management is handled by the PCM, the body security is handled by the SJB and the restraint controls are handled by the RCM. Your car is full of computers and none of them control everything.
Now, I think you are talking about switching out your PCM's.......did both PCM's have the same calibration code? The PCM has nothing to do with the 'transmitter' in the PAT's key. The PAT's system is managed by the SJB. When a dealer changes out your PCM they perform a function called "inhale/exhale". Basically the WDS tool captures key data from the OE PCM and holds that in memory (inhale). Then they plug in the new PCM and transfer that memory to the new part (exhale). This step is crucial to the PCM functioning correctly because it exists in the vehicle's Module Communication Network.
You guys really shouldn't be touching your vehicles electronics with such limited knowledge on the subject. I know you want to work under the hood.....but a modern automobile is far too complex for the lay person.
Old Jul 26, 2007 | 04:07 PM
lldsandsll's Avatar
lldsandsll
ORIGINAL: bascho
yes, both PCM's had the same code.
i wasn't worried about screwing around. if he broke anything, he'd fix it. either that, or ford warranty
Old Jul 26, 2007 | 04:32 PM
A_J's Avatar
A_J
ORIGINAL: bascho
I agree bascho, but I'm curious if you know of any resources out there for learning the electronics/computer systems in the S197s, or Fords systems in general. I don't neccessarily intend on working on those systems myself, but I'm a firm believer in knowing as much as I can so I can tell when a shop is blowing smoke.. I was a trained mechanic up until the mid '90s, but I've kind of fallen out of the loop when it comes to more recent designs, for example, nowadays you see reference to the cars networks.. I should be able to grasp it - I'm a database programmer now.. just curious about things like the things you talk about above, protocols, etc.. thx
Old Jul 26, 2007 | 04:37 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
ORIGINAL: bascho
Wow WDS. Thats an old computer, We use the VCM and Toughbook now.
If you wanted to try that with your friends car all you would also need to do is switch the key cylinders also. The PCM won't start the car until it recognizes the proper key thats programmed. If a car comes in with a bad PCM we have to upload the info from Ford and Erase all key codes and reprogram 2 keys before the car will start.
What problems was he having?
