Lose Shift Knob
Old Jul 27, 2007 | 11:24 AM
s197richie's Avatar
s197richie
I ♥ Acer
Default RE: Lose Shift ****
^^^ um, I'd advise against eitherof those, just in case you ever have to get the **** off...use the blue medium-strength threadlocker...it's a good locker but will break loose if you apply enough elbow grease...
Old Jul 27, 2007 | 11:41 AM
kovar's Avatar
kovar
In my experience, the entire shaft -- not simply the **** -- turns. I tried to replace the **** with a hurst **** and thought it was very basic too, but then the entire shaft started to unscrew. I was able to screw it back in place and get it aligned, but without the new ****.
Old Jul 27, 2007 | 11:51 AM
Aziraphale's Avatar
Aziraphale
A little lock tight if it really bothers you should fix the problem.
Old Jul 27, 2007 | 11:57 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Try putting a washer on the inside of the ****. Locktight will make it hard to take if should you ever need to.
Old Jul 27, 2007 | 03:09 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: s197richie
um, come on, its a plastic **** with plastic threads.
Neither JB or LockTite bonds to plastic so removal is simple
but it adds just that right amount to get it tight. The shifter is
bottoming in the OEM **** when it gets tight. Fill that with
some JB and tighten until its just about right and let it harden.
Then turn it the last little bit so everything is straight and tight.
Old Jul 28, 2007 | 01:06 PM
Black07Stang's Avatar
Black07Stang
I had the same problem....slide the boot off the shift **** and turn the shift **** till its tight, then put the boot back on the washer that holds it in place. It should tighten up to where u want it.
Old Jul 28, 2007 | 01:32 PM
FlaPony's Avatar
FlaPony
Buy an aftermarket shifter and get rid of the POS stock shifter...problem solved and you'll be much happier
Old Aug 1, 2007 | 10:56 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: FlaPony
+1
Ford = POS
Aftermarket = $$
carid
Jul 8, 2016 09:55 AM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
