Just noticed recently, engine bay paint peeling
Well i believe i read someone that the tank located on the driver side in the engine bay near the window, has a leaking problem so i got a flashlight and start looking and notice dried leak marks on it.........and as i looked further down, i notice that it had been falling on a part of the car that was painted and well it ate the paint right off and it was all bubbled and i could see the metal of the car....what will ford do? and has anyone had this problem? im tired of taking my car to ford, hating having them drive it or even work on it.
RE: Just noticed recently, engine bay paint peeling
I think your reffering to the brake booster? If it is leaking brake fluid is corrosive as hell and i can see why the paint is bubbling. And if you are still under warranty I dont see why ford wouldnt fix it. I would just worry about them not doing a good job.
Check your brake resevior and see if it is leaking. This is the condition that you are describing, and I have had issues with it myself. The cap leaks - I just remember to clean it off before it drips on the paint periodically. I even had the dealer replace the cap, still leaks.
there is a known leak from the brake fluid reservoir and that will cause corrosion and Ford dealers will repaint the engine bay that is affected. I know there are threads on this just dont remember where. Teflon tape on the reservoir will stop that leak in its tracks. Hope it helps
ORIGINAL: aschultz91
yea i kno i read reports on it somewhere too and teflon tape will be used as soon as the engine bay its repainted, but only by a shop i know and ford will approve, not having my car sent all the way to garfield when i kno one that is much closer and works on high class cars and gives me special pricing :-)...in this case that dont matter since ford is paying lol.
I've also heard that Ford overfills the brake res too! Can anyone show a pic of what is the correct level?
I had my car in for the same leak and all they said was that they removed some fluid... so of course, it still leaks a little! No paint damage, but that could be due to all the water that gets in there when I hose off my undercarraige when washing the car.
ORIGINAL: Orion_240
