heat reduction mods
ORIGINAL: 2k05gt
I have been data logging my tune, trying to figure out why my car is having issues. so I took a good look at the JLT II setup and found a lot of flaws. so I started to address them one at a time. My MAF AI Temps are 145+ deg. with ambient Temps of 85 deg.
ORIGINAL: 28HopUp
Have your measured your AI temps after adding the insulation to see how much it went down?
ORIGINAL: 2k05gt
I will post tonight
Try unbolting the rear of the hood and inserting rubber between the bracket and the bolt holes. The hood will shake a little bit while you're driving down the road, but I dropped the running temp on my old car by about 10 degrees (consistent) by doing this. The hood was only lifted by about 1/4-1/2 an inch, and it only costs you about 10$. The bolts will be a bit shorter, but you can find a set with the same profile at Autozone.
ORIGINAL: DelStang86
Kenne Bell says on their website that the coolest air is in the very lowest front area (passenger side) of the engine bay. They haven't answered any of my e-mails, so I'm trying to rig sensors myself to measure the temps in different areas of the engine bay. If I find low temperatures in the low right front area, I'll cobble together an air intake and let you guys know if it makes a difference.
2k05gt, what temperature sensors are you using?
Sleeper2
Sleeper2
