heat reduction mods
Old Jul 30, 2007 | 02:35 PM
mattstang2007's Avatar
mattstang2007
Default heat reduction mods
are there any heat reduction mods that are simple and dont cost an arm and a leg?
Old Jul 30, 2007 | 02:59 PM
s197richie's Avatar
s197richie
I ♥ Acer
Default RE: heat reduction mods
unbolting your hood is free lol...
Old Jul 30, 2007 | 03:01 PM
mattstang2007
lol sad thing is if i could do it i would
Old Jul 30, 2007 | 03:06 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
A hood. But then that's not cheap,
Old Jul 30, 2007 | 05:22 PM
WALLACE's Avatar
WALLACE
a shaker hood will put cool air under the hood and the big hole needed to make it fit
will also act as a heat extractor. works for me.
Old Jul 30, 2007 | 05:26 PM
Dex's Avatar
Dex
cut some holes in the hood and put some chicken wire over it. it will look like a civic!
Old Jul 30, 2007 | 10:50 PM
sharkbait20's Avatar
sharkbait20
oil and/or transmission cooler (i think they are both under or around $100-200) not positive though
electric fan (no idea of cost)
'upgraded' thermostat maybe?
Old Jul 30, 2007 | 10:59 PM
jerjan's Avatar
jerjan
What type of heat extraction problem are you having?
Old Jul 30, 2007 | 11:24 PM
WhiteStallion06's Avatar
WhiteStallion06
heat extractor hood but as mentioned before that would cost a bit
Old Jul 31, 2007 | 08:07 AM
2k05gt's Avatar
2k05gt
I have been data logging my tune, trying to figure out why my car is having issues. so I took a good look at the JLT II setup and found a lot of flaws. so I started to address them one at a time. My MAF AI Temps are 145+ deg. with ambient Temps of 85 deg.
[IMG]local://upfiles/25187/A3C778B89FA84ED99A2A6509405696FB.jpg[/IMG]
I first took the stock air box and cut the bottom off the fit the JLT II heat shield to block the heat coming from underneath the shield
[IMG]local://upfiles/25187/E97C9174E3A84BCBA36D440B0B6FD29F.jpg[/IMG]
then I used some adheasive back insulating foam with reflective foil and cut it to fit the outside of the shield
[IMG]local://upfiles/25187/9915DDA95A7747B4B18C41279FB67257.jpg[/IMG]
[IMG]local://upfiles/25187/AFCF47BA174945CBA2BBB49BFA1B8E6B.jpg[/IMG]
and finished the edge with clip on door weather striping to seal against the hood and body.
[IMG]local://upfiles/25187/8281683E489A4B9AB4F791BE0F2D1575.jpg[/IMG]
