gt500 bumper on a gt/v6 mustang?
#23
RE: gt500 bumper on a gt/v6 mustang?
Fender Liner is listed under Fender Components ... about $13 each ... V6 and Shelby are the same.
Can't seem to find the wiring harness in the online OEM catalog .... I ordered the entire setup from Kevin at Clevenger Ford so he knew all the parts ...
#26
Well ... if you order online everything will be cheaper except you have to pay shipping. If you pay local ... the dealer will probably mark it up and charge you sales tax. Hard to say which way works out better. Also ... if you let your body shop order it ... they can get it wholesale and not pay tax ... if they will do that for you.
#27
The following list details the parts necessary to perform the GT500 front fascia conversion. When reading this post, realize that your existing Mustang fascia may or may not have fog lights, and you must carefuly investigate any wiring harness issues you may encounter. For this post, it is assumed that you have the Mustang GT with fog lights located in the upper radiator grille.
NOTE 1: The only item needed from the GT500 wiring harness is the female connector for the new fog lights. The necessary female connector may or may not be avaialbe as a separate Ford part. If not, then you’ll need to purchase the GT500 wiring harness and cut off the needed adapter. An alternative could be to hardwire the existing GT wiring harness to the fog lights. Other’s may chime in and offer their suggestions.
NOTE 2: The front half of the driver and passenger inner wheel well guards are not identical for the GT500 and GT. It may be possible to alter the stock GT wheel well guards to fit the holes on the new GT500 bumper and lower valence. I chose to purchase the GT500 guards since they were approximately $30 combined.
Part #, Quantity, Name
[ul] 7R3Z-17D957-APTM, 1, Bumper assembly
7R3Z-17K945-AA, 1, Grille, lower
7R3Z-8200-A, 1, Grille, radiator
7R3Z-8B455-A, 1, Bracket
7R3Z-8B455-B, 1, Bracket
7R3Z-17C861-A, 1, Reinforcement
7R3Z-17C861-B, 1, Reinforcement
7R3Z-17626-AB, 1, Lower valence (optional as it does not alter appearance of fascia without it)
7R3Z-17C882-A, 1, Isolator
7R3Z-15200-A, 2, Foglamp (see Note 1)
7R3Z-14290-EA, 1, Wiring harness (see Note 1)
7R3Z-8C291-AA, 1, Shield
7R3Z-13008-A, 1, Headlamp
7R3Z-13008-B, 1, Headlamp
5R3Z-16103-AA, 1, Guard, front (see Note 2)
5R3Z-16102-AA, 1, Guard, front (see Note 2)
W302597, 8, Bolt (quantity is approximate, I can’t remember how many are needed)
S713547-S439, 8, Nut, spring (quantity is approximate, I can’t remember how many are needed)
W711274-S439, 6, Nut, spring (existing nut, spring may be used, I didn’t know that until after purchasing them)
W706805-S902, 6, Screw (existing screw may be used, I didn’t know that until after purchasing them)
[/ul]
[/ul]
#28
ORIGINAL: brendend
can you guys check and make sure ive orderd everything needed heres the invoice from the website:
Items Ordered:
Item: Front bumper, Bumper and components, Bumper cover, Bumper cover - Shelby - Shelby
Price: $391.55
Tax: $0.00
Qty: 1
Total: $391.55
Item: Front bumper, Bumper and components, Bumper cover, Side bracket, Side bracket Left - Shelby - Shelby
Price: $22.34
Tax: $0.00
Qty: 1
Total: $22.34
Item: Front bumper, Bumper and components, Bumper cover, Side bracket, Side bracket Right - Shelby - Shelby
Price: $22.34
Tax: $0.00
Qty: 1
Total: $22.34
Item: Front bumper, Bumper and components, Bumper cover, Reinforcement, Reinforcement Right - Shelby - Shelby
Price: $13.38
Tax: $0.00
Qty: 1
Total: $13.38
Item: Front bumper, Bumper and components, Bumper cover, Reinforcement, Reinforcement Left - Shelby - Shelby
Price: $31.93
Tax: $0.00
Qty: 1
Total: $31.93
Item: Front bumper, Bumper and components, Bumper cover, Brace, Brace Right - Shelby - Shelby
Price: $20.23
Tax: $0.00
Qty: 1
Total: $20.23
Item: Front bumper, Bumper and components, Bumper cover, Bracket, Bracket Right - Shelby - Shelby
Price: $12.06
Tax: $0.00
Qty: 1
Total: $12.06
Item: Front bumper, Bumper and components, Bumper cover, Bracket, Bracket Left - Shelby - Shelby
Price: $10.13
Tax: $0.00
Qty: 1
Total: $10.13
Item: Front bumper, Bumper and components, Isolator, Outer, Outer - Shelby - Shelby
Price: $56.14
Tax: $0.00
Qty: 1
Total: $56.14
Item: Front bumper, Bumper and components, Isolator, Inner, Inner - Shelby - Shelby
Price: $6.30
Tax: $0.00
Qty: 1
Total: $6.30
Item: Front bumper, Bumper and components, Impact bar, Impact bar - Shelby - Shelby
Price: $101.35
Tax: $0.00
Qty: 1
Total: $101.35
Item: Front bumper, Bumper and components, Valance panel, Valance panel - Shelby - Shelby
Price: $44.35
Tax: $0.00
Qty: 1
Total: $44.35
Item: Front bumper, Bumper and components, Lower grille, Lower grille - Shelby - Shelby
Price: $111.43
Tax: $0.00
Qty: 1
Total: $111.43
Item: Front lamps, Headlamp components, Headlamp assy, Shelby, Shelby Right
Price: $99.49
Tax: $0.00
Qty: 1
Total: $99.49
Item: Front lamps, Headlamp components, Headlamp assy, Shelby, Shelby Left
Price: $99.49
Tax: $0.00
Qty: 1
Total: $99.49
Item: Fender, Fender and components, Fender, Gt, Gt Left
Price: $106.00
Tax: $0.00
Qty: 1
Total: $106.00
Item: Front lamps, Fog lamps, Fog lamp assy, Shelby, Shelby Back
Price: $83.57
Tax: $0.00
Qty: 1
Total: $83.57
Items Ordered:
Price: $391.55
Tax: $0.00
Qty: 1
Total: $391.55
Price: $22.34
Tax: $0.00
Qty: 1
Total: $22.34
Price: $22.34
Tax: $0.00
Qty: 1
Total: $22.34
Price: $13.38
Tax: $0.00
Qty: 1
Total: $13.38
Price: $31.93
Tax: $0.00
Qty: 1
Total: $31.93
Price: $20.23
Tax: $0.00
Qty: 1
Total: $20.23
Price: $12.06
Tax: $0.00
Qty: 1
Total: $12.06
Price: $10.13
Tax: $0.00
Qty: 1
Total: $10.13
Price: $56.14
Tax: $0.00
Qty: 1
Total: $56.14
Price: $6.30
Tax: $0.00
Qty: 1
Total: $6.30
Price: $101.35
Tax: $0.00
Qty: 1
Total: $101.35
Price: $44.35
Tax: $0.00
Qty: 1
Total: $44.35
Price: $111.43
Tax: $0.00
Qty: 1
Total: $111.43
Price: $99.49
Tax: $0.00
Qty: 1
Total: $99.49
Price: $99.49
Tax: $0.00
Qty: 1
Total: $99.49
Price: $106.00
Tax: $0.00
Qty: 1
Total: $106.00
Price: $83.57
Tax: $0.00
Qty: 1
Total: $83.57
#29
The Shelby GT uses GT and GT/CS parts ... all the parts listed as Shelby are specifically for the GT500 ... AFAIK ... Shelby is no allowing anyone to buy the Shelby GT specific parts so they wouldn't be available anyway.
