Trouble code help
Old Aug 1, 2007 | 01:11 AM
ANBAUTO's Avatar
ANBAUTO
Default Trouble code help
so today while driving home the engine went to safe mode and i popped a code P0102 Mass or Volume Air Flow Circuit Low Input.
Does anyone know why i would get this?
Old Aug 1, 2007 | 01:19 AM
hammeron's Avatar
hammeron
Default RE: Trouble code help
i'd check the cai fittings to make sure there
is no air leak.....
Causes
A code P0102 may mean that one or more of the following has happened:
[ul][*]The MAF may be disconnected, or a wiring connection may be bad[*]The MAF may be dirty or otherwise contaminated (Note: if you use a[*]reusable oiled air filter, be careful not to apply too much oil or that can contaminate the MAF).[*]The MAF sensor may be faulty[*]The vehicle computer may be faulty (very rare) [/ul]
Old Aug 1, 2007 | 11:48 AM
ANBAUTO's Avatar
ANBAUTO
I will try and clean the MAF since the oil from the filter wouldnt reach it since ive got the procharger on. also i will check the wiring also could it be a faulty mafia unit ive had it on for some time now
Old Aug 2, 2007 | 11:37 AM
ANBAUTO's Avatar
ANBAUTO
The MAFia that i had is bad i removed it from the car and the problem is gone. the item was only 2-3 months old anyone get a bad one?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
