Dead Battery and "Skipper 500"
RE: Dead Battery and "Skipper 500"
Like I mentioned earlier, you need to either identify the radio as the source or eliminate it as a suspect. Troubleshooting methods will help you isolate the suspect device(s) causing the drain. AND IF pulling the fuse stops the drain, I'd STILL see what else is on that fuse circuit before jumping to conclusions and ripping out your head unit.
Rick
[sm=smiley34.gif]
Rick
[sm=smiley34.gif]
well, no call to the dealer yet cause i still dont have anything to back up any sort of claim to anything and my local dealer is staffed by absolute DOUCHEBAGS.
has anyone had my passenger window auto-up problem? seems weird that now it doesnt work right after battery dieing.
*bangs head against wall* electrical gremlins FTMFL!!!!!!!
ORIGINAL: my77stang
Mike
ah HA, instructions!!!!! i wouldnt have ever even thought to check, cause why in the hell would something like that reset (and only on one window) after havnig a dead battery - hell i have disconnected it before to reset the adaptive learning crap and it never changed the windows.
how many f'in worthless features do these cars have? i just want the damn thing to go down the road with a quickness and not give me any crap. is that too much to ask for?
I also had the window issue - follow the destruction booklet & you can fix it in minutes
My battery did drain once & once only (causing aforementioned window issue) I have noticed on a couple of occasions that the shaker 500 does not switch itself off with the ignition (sound goes off, therefore will assume amps power off, but the display stays on) it's an intermittent fault & as is typical with those I cannot get it to do it when I'm at the dealer.
It is frustrating but if you want proof before going to the dealer attach a multimeter to your battery with the ignition off & see if there is a drain on the battery. If your dealership is such a waste of time is there another one nearby you can go to? I live in Saskatoon & even here there are 2 Ford dealerships in town & another 2 within an hours drive.
Skipping issues - only with burnt cd's? what write speed were they burnt at? I have no specific issues that I can put down to burnt cd's but only use an x8 write speed.
the skipping was on a burnt cd, probably burned at 48x but the same cd never had problems before and recently it started skipping on us. like not a repeat kinda skip - but a sound cuts out for a few seconds at a time kinda skip.
so it sounds like chances are they arent going to replace the radio..... have any of you guys gotten a replacement stereo from the skipping problems? i know everyone says they are infamous for being a piece of crap.
ORIGINAL: ohnoesaz
dont put red locktite on your oil drain plug
[sm=alcoholic.gif]
sorry, but gotta have some humor at other's expense, every now and then.
No im not really a mean person.
Mike
