I know that the stock injectors are good at least up to 500 Crank HP, the fuel pump has to be upgraded though to support that.
The other way is to leave the stock fuel pump in and go to 60lb injectors. The pump is running hard (good to 500hp) but at least the injectors are installed ready for more power later.
Hmmm, well, after 500hp I couldn't say for sure but my tuner said the stocks were "well capable" of handling fuel demand for 500.
How much are you going for?
You are going to want to upgrade to 60lbs. I am running GT500 dual fuel pumps that apparently hold up to 700RWHP without problems, after that GT40 dual pumps would be your next bet.
