Need Some Help-EDITED WITH NEW SIZES AND TIRES
Old Aug 5, 2007 | 06:07 PM
Kwiatkowski18's Avatar
Kwiatkowski18
Default Need Some Help-EDITED WITH NEW SIZES AND TIRES
I posted this in the Tire section but it seems rather slower than the other sections of these forums and I need an answer fairly quick so that my tires can get here as quickly as they can.
I placed an order at the tire rack last week for Sumitomo HTR Z II 275/40/18 (for the rear) and 255/45/18 (for the front) tires. A guy from the tire rack called me with an issue about the tires. He said that with the fronts, they would be about an inch higher than the rears. Is this correct? Is there a drastic issue about that appearance wise? Does anyone have the same set up with pics? Anyone know what I should do?Any help would be greatly appreciated because I want to get this issue cleared up ASAP. Thanks.
My car is a 2006 Ford Mustang V6 Coupe and has 18X10 bullitts in the back and 18X9 bullitts in the front.
EDIT: Would it be better to run 245/40/18's in the front than 255/45/18? The middle number means the height of the tire right? What would everyone recommend to me here?And I don't want tires that make my car look like a rice burner that has no rubber at all and is all rim. Thanks guys. I appreciate it.
Old Aug 5, 2007 | 06:14 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: Need Some Help
Alot of rim and tire set ups do this. On our SEMA car we're running a 30 series in front and a 25 in the rear. I think the main reason for the added rubber up front is for the extra cushion on the rim. Since the wieght of the fron is more due to the motor. But a 40 series tire is not that bad. I'm running 35's all around. Tires aren't my specialty area so hopefully someone has better info.
Old Aug 5, 2007 | 06:38 PM
Kwiatkowski18
I appreciate the help. That does make sense. I never thought of that before.
But before I make my decision, I'd like to hear from others as well on this issue.
Old Aug 5, 2007 | 06:42 PM
howarmat's Avatar
howarmat
s197 Junkie
Custom wheels, chrome wheels, alloy rims - BIGCUSTOMWHEELS
Old Aug 5, 2007 | 07:00 PM
TJ's Avatar
TJ
ORIGINAL: Kwiatkowski18
I (imo) wouldn't go with tires that are 1" taller in the front than the rears but yes I believe 245x40x18 would match the height of the rears but double check that as some tire companys vary a little. The other way if you found tiresif possible 275x45x18 rears 255x40x18 for the fronts but double check this out height wise.
Old Aug 5, 2007 | 07:01 PM
Kwiatkowski18
Thanks for the website. It's great for sizing and speedos, but I'm still looking for more opinions.
Old Aug 5, 2007 | 07:05 PM
Kwiatkowski18
ORIGINAL: TJ
I (imo) wouldn't go with tires that are 1" taller in the front than the rears but yes I believe 245x40x18 would match the height of the rears but double check that as some tire companys vary a little. The other way if you found tiresif possible 275x45x18 rears 275x40x18 for the fronts but double check this out height wise.
Thanks for the info. I cannot go any higher in the back because the tires I'm looking at do not go above 40. But as long as the car is more or less level sitting than a higher front stance, I'll be happy.
Does anyone have pics of an 05+ mustang with 40's all around? Thanks.
Old Aug 5, 2007 | 07:16 PM
TJ's Avatar
TJ
ORIGINAL: TJ
Kwiatkowski I edit my post that would be 275x45x18 rears and I meant 255x40x18 up front (not 275x40x18) if possible but since the tires you pickeddon't come in those sizes won't work then.. I myself decided to go with 255x45x18 (27" tall) all around which are coming in next week also ordered new rims which should be in about the same time.
Old Aug 5, 2007 | 07:31 PM
howarmat's Avatar
howarmat
s197 Junkie
just go 275/40 all around....nothing wrong with that really
Old Aug 5, 2007 | 08:23 PM
Kwiatkowski18
I dont want to go 275's all around. I want wider tires in the back.
How would this work out: 275/40/18 in the back, 245/40/18 in the front? I don't want to have the ricer look with the tires, so is 40 enough all the way around? And would a 245 fit on a 18X9 rim (I'm sure it will but it's nice to double check)? Thanks everyone so far.
