Check brake system
Old Aug 13, 2007 | 10:10 PM
red3784's Avatar
red3784
Default Check brake system
Has anyone has this come up on there screens as well? I have an 06 gt, is it the brake pads, or could it be something else?
Old Aug 14, 2007 | 11:32 AM
red3784's Avatar
red3784
Default RE: Check brake system
anyone?
Old Aug 14, 2007 | 11:40 AM
MrSandman's Avatar
MrSandman
Does it say "check break" or are the TCS and ABS lights on? The latter happened to me after I ran on a dyno.. I just had to chirp the tires and they turned off.
ORIGINAL: red3784
anyone?
Old Aug 14, 2007 | 11:45 AM
partsbill's Avatar
partsbill
BRAKE Warning Indicator
The brake warning indicator alerts the driver if any of the following brake system conditions are present: the parking brake is set, the brake fluid level is low, the ABS module detects a base brake system failure, there is a loss of communication between the instrument cluster and the SJB, or there is a loss of communication between the instrument cluster and the ABS module.
Anti-lock Brake System (ABS) Warning Indicator
The ABS warning indicator informs the driver of a malfunction in the ABS system. Inputs are provided by the ABS module over the communication network.
Old Aug 14, 2007 | 11:56 AM
red3784's Avatar
red3784
Actually the tcs, abs, and park brake light are one, as well as check breake system, what do you guys recomend?
Old Aug 14, 2007 | 12:04 PM
RED121572's Avatar
RED121572
Shoot it.
Mine does the samething from time to time. After a few key cycles, the lights go out.
Old Aug 14, 2007 | 12:14 PM
red3784's Avatar
red3784
haha i have had it for 2 days now, the car does drive fine tho
Old Aug 14, 2007 | 04:26 PM
howarmat's Avatar
howarmat
s197 Junkie
dealer.....brakes are important and need to work
Old Aug 14, 2007 | 05:54 PM
saltzy's Avatar
saltzy
I'm getting the 'brake fluid level low' message sometimes lately, only in hot weather and always within 1 minute of starting the motor. Thing is, fluid level is fine, I even topped it off. I know what you're thinking--low brake pads, right? Thing is, they're not--but I bought new Hawks anyway and will be putting them on soon. Unless the tolerance for pads is abnormally conservative, if this doesn't fix it it's going to be a tough one to bring to the dealer since I can't replicate it on demand.
(FYI, when the Low Brake Fluid Level message appears, the TCS is disabled as indicated by the dash lights.)
Old Aug 14, 2007 | 07:50 PM
red3784's Avatar
red3784
Oh, good information thanks guy, I have to bring it back to ford, because the heat shield is lose, so i figure i might as well have them take a look at it
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
