reeks like gas !
RE: reeks like gas !
ORIGINAL: svt93style
Sounds like the tune is running fat...rich.
All the online tuners always send there tunes out rich, its a safety issue for them.
Take it in to a local dyno and tune it out just right and your problem will be solved.
im running tunes from B chips
the rich smell came from when i was running the 93 octane, but now that i have switched back to the 87 octane tune it still stinks, something it never did before when running 87
but ive ordered 2 new MAF mounting screws from the dealership, should take about a week to get it, i'll throw it back to stock and see where that leaves me
That throws a bit of a loop in the equation, but still could be the tune.
When you dealing with a gas smell you should be able to narrow it down. Start at the fuel tank smell around, work your way up.
Follow the fuel lines running fromt the tank, check the injectors etc...
Best of luck.
Keep us posted, I'd like to know what it is.
Also for my curiousity when do you notice.
Start up? Hot or cold days? Cruising? Accel? Decel? Idle? All around?
Best of luck.
ORIGINAL: doode
stupid question, but where to find it?
second, i would take it back to the dealer, but when swapping out the MAF from the stock intake to the C&L, i dropped one of the damn screws and lost it
ive yet to find time to get back to the dealership to order a new mounting screw, but thats the only reason why i havent got back to stock yet
ORIGINAL: 8178A
Check the gas tank vent hose.
bulges out from the spare tire well. There is a black plastic cover over
your evap purge canister. The vent goes thru a filter before going to atmosphere.
Crawl on under and remove the plastic cover. Everything associated with
the gasoline vapors resides there.
ORIGINAL: s2k
If you have an offroad pipe youll get a nice smell of fuel when you at a stoplight or running idle.
from 1st generation cats.
ORIGINAL: GidyupGo
Yea, and that parts of the jungle aren't.
ORIGINAL: 157
I love the smell of burning napalm in the morning.
Kinda reminds you that you are still alive.
Burning jungles is way not cool cartman....
