how to remove shift knob?
Old Aug 14, 2007 | 09:26 PM
enzo51's Avatar
enzo51
Default how to remove shift ****?
hi,
I am trying to remove the shift **** on my manual. It seems that I cannot just unscew it.
Can anyone tell me how to remove it?
Thx
Old Aug 14, 2007 | 09:33 PM
armour845's Avatar
armour845
Default RE: how to remove shift ****?
I'm sure if you twist hard enough in the counter clock wise direction the handle will loosen up and you can remove it. The shifter boot will want to twist with the **** if you don't hold it in place or roll it down away from the ****.
Old Aug 14, 2007 | 10:05 PM
owero01's Avatar
owero01
See Tacobill's howto guide to install MGW short throw shifter.
https://mustangforums.com/m_3000094/tm.htm
Old Aug 14, 2007 | 10:37 PM
Humboldt Stang's Avatar
Humboldt Stang
Just pop the boot down off of the ****, unscrew, voila!
Old Aug 15, 2007 | 09:32 AM
157dB's Avatar
157dB
Cut & Paste Expert
Pull up and twist counterclockwise.
Twist until you cant twist no more.
After practicing, go out to the stang
and pull and twist there.
On second thought, are you mechanically
inclined? Maybe you should take it to the
stealership for assistance.lol
Old Aug 16, 2007 | 11:57 AM
kovar's Avatar
kovar
When I attempted to do the same thing, the entire shaft began to unscrew from the transmission itself. From other posts I've seen, this appears to have happened in other cases. I also understand that since the boot attaches to the stock ****, it may be necessary to"jury-rig" something to hold the boot.
Old Aug 16, 2007 | 12:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
You gots a funky shifter.
Its not attached to the transmission
but hooked to a linkage to the tranny.
If yours is a spinnin, you have problems.
You can jerry rig a boot holder but
you will not like it.
https://mustangforums.com/m_3497396/tm.htm
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
