Speaker upgrade help please
Old Aug 15, 2007 | 09:01 PM
lldsandsll's Avatar
lldsandsll
Default RE: Speaker upgrade help please
also, all the other speakers have a lot of options for replacement. if you replace all the speakers get an 8 channel amp for the 8 speakers, make sure it's a good amp. i dunno if it can be hooked up to the factory head unit, someone else answer this. that'd be great tho. i wanna hook up to the HU. i dont think the stock speakers need replacing if you just wanna add some bass with those 8's tho.
Old Aug 15, 2007 | 09:11 PM
howarmat's Avatar
howarmat
s197 Junkie
ORIGINAL: lldsandsll
....there are only 4 speakers and 2 subs with the 500 and 4 subs with the 1000....and yes all 4 stock 5x7/6x8 should be replaced if you get a new HU....they have a 25w stamp on the back....peak power i believe
Old Aug 15, 2007 | 09:17 PM
Bmr4life's Avatar
Bmr4life
WHAT?!?!?! An 8 channel amp? You don't need that, I don't think it even exist.
Old Aug 15, 2007 | 09:20 PM
pegasusphototx's Avatar
pegasusphototx
For those who want to put component speakers where the fron 5x7 speakers are, you can use this:
http://cgi.ebay.com/Metra-82-5601-Fo...QQcmdZViewItem
You will need to dremel off the 'lip' for the 5x7 speaker so that the 6x8 adapter will screw on. Took a little time to get it all sorted out, but it's a great solution for a component option.
-danny
Old Aug 15, 2007 | 10:10 PM
drbobvs's Avatar
drbobvs
Infinity Reference 6812's. $100 or less/pair. Replace all 4 please, you'll be glad you did. If you get them from Crutchfield, they'll send you the adapers and the door and rear panel removal diagrams. Real easy mod, and will improve the sound greatly. They are very efficient and will play loud with the stock HU. They have ALOT of treble, but excellentclearvocals.
Old Aug 15, 2007 | 10:11 PM
lldsandsll's Avatar
lldsandsll
ya they make even more channels then that. i didnt know the car was only6 speakers, tho it makes sense. for some reason i always thought it had 8. those speakers sing considering they max out at 25. i wasn't planning to replace my HU. i just want the 8's and an amp to power em. can that be done with the stock HU howarmat?
Old Aug 15, 2007 | 11:01 PM
Bmr4life's Avatar
Bmr4life
I was just digging through my old car audio stuff and ran across my old Polk Momo MM6 6 3/4" Component Set. Would the midbass driver in this set be enough to replace the stock 8's in the doors or do you guys think I'd be lose some bass? I'd power them with a 2x150 (rms) amp.
http://www.crutchfield.com/S-Ki1y0gk...0&I=107MM6
Link to the old component set.
Old Aug 16, 2007 | 04:40 AM
howarmat's Avatar
howarmat
s197 Junkie
I would recommend replacing the 4 main speakers and the HU. It can be done pretty cheap and it will balance better....just replacing the HU might be too much power for the paper speakers to really get the benefit so replacing the speaker will fix that.
Old Aug 16, 2007 | 07:37 AM
BLD06GTVert's Avatar
BLD06GTVert
Wow, good stuff here guys...keep it coming! I'm learning alot!
I appreciate the help!
Old Aug 16, 2007 | 08:48 AM
holdstill79's Avatar
holdstill79
There are plenty of good speakers and plenty good subs that fit in the door. At my stereo shop, we work on 2-3 S197s a week. If you can't do it all at once, replace the door speakers with a decent name brand that is a low wattage/high sensitivity speaker (ie: memphis PR57 or boston SX) Roll with that until you can get a new radio. Then, do door subs and an amp. Lastly do an amp for the door speakers. Many speakers will sound good if setup right. What do you feel that you are missing from your stereo system? Clarity? volume? bass? Thats what you need to figure out before just going to buy speakers, and buy them based on your needs (not what other people like)
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Sixer4Life
Sep 29, 2015 07:03 PM
