Engine light
Old Aug 24, 2007 | 05:33 PM
deemo's Avatar
deemo
Default Engine light
I just took my07' mustang gt in the dealership because the engine light has been coming on and off.I have the SLP Pwerflow x-pipes and SLP Loudmouths on. They said that, that was the cause of that and that there is nothing wrong with my car and that is just that the sensors might not be reading what they are used to with a stock excaust. Does that sound right and has anyone else experienced similar problem?
Old Aug 24, 2007 | 05:37 PM
Thurman's Avatar
Thurman
Default RE: Engine light
Do u have cats? If so that is b/s
Old Aug 24, 2007 | 05:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: deemo
Are all of your O2 sensors plugged in?
Take it to Autozone and have them give you the codes for free, then post them here.
Catted X pipe with all sensors plugged in and functioning should not be an issue. Codes will tell.
Old Aug 24, 2007 | 05:44 PM
Thurman's Avatar
Thurman
Ford right now is very tight with spending warranty dollars, so they denying a lot of claims.
Old Aug 24, 2007 | 05:51 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That's agiven but knowing the codes will point him in the right direction. It could be as simple as one of the02 sensors harnesses is loose. It happened to me. I was doing some workunder mycar and repositioned one of the02 harnesses. In doing so I unknowingly pulled it out a bit. Got a CEL a couple of days later.Can't remember the code right now but it wastelling me02Heater failure Bank 2 Sensor2. Got under the car, saw the loose harness, pushed it back in. Cleared the code..done. No dicking around with the dealership and my aftermarket exhaust. That was 3 months ago.
Old Aug 24, 2007 | 06:01 PM
deemo's Avatar
deemo
Will do tnx...I hope thats all it is, dont get me wrong the car runs fine but I just want to be sure
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
Nov 5, 2015 04:18 PM
J.casone400
Aug 28, 2015 09:33 PM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
drumhedd2005
Aug 13, 2015 09:59 AM
