Front corner Light Removal
Old Aug 26, 2007 | 01:24 PM
05Retro's Avatar
05Retro
Default Front corner Light Removal
Can anyone tell me what holds the front corner lights in. Pics would help if you have any.
Old Aug 26, 2007 | 01:27 PM
mlcrycc's Avatar
mlcrycc
Default RE: Front corner Light Removal
There are two pins on the outboard side of the corner light. They have wing type pieces on them. Compress the wings, and the light pivots back. On the inboard side, there is a pin and slot setup. Once you pivot the light, it pulls right out.....
Puttin in clears??
Mike
[IMG]local://upfiles/13557/0C50ACC3B56B4056A0603B40FD5288A0.jpg[/IMG]
Old Aug 26, 2007 | 03:24 PM
Aziraphale's Avatar
Aziraphale
Turn the wheel so that it points out, remove a few of the front inner fender screws and pull it back. Then just pull the light out as stated above. Couldn't be easier.
Old Aug 26, 2007 | 04:22 PM
olvanish's Avatar
olvanish
ORIGINAL: Aziraphale
yup, make sure you do that because if you try to lift up your car and reach it from the bottom likeI didit will make your life harder and take more time.
Old Aug 26, 2007 | 06:15 PM
05Retro's Avatar
05Retro
Thanks guys clears are on their way. MlcryccPic was great.
spectreman
Mar 31, 2016 09:26 PM
dubarado
Dec 23, 2015 01:16 PM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
inyadreems
Aug 21, 2015 09:10 AM
