trunk interlooler pic
Old Aug 29, 2007 | 03:08 PM
hammeron's Avatar
hammeron
Default RE: trunk interlooler pic
if it gives you piece of mind, then it's all good.
Old Aug 29, 2007 | 03:09 PM
marcuskeeler's Avatar
marcuskeeler
I particularly like the quality tie wraps holding the longass pipes off the ground, very 'pro' LOL
Old Aug 29, 2007 | 03:11 PM
Sherwood06GT's Avatar
Sherwood06GT
ORIGINAL: blackhorse05
it helps keep the s/c cooler. but more cooler than you might think. also it makes it possible to put a lot of ice in the tank for track nights or street racing.when you s/c you get this tiny little reservoir, right next to or in front of the s/c in the engine bay. do you understand how hot it gets in their. your air will get cooler from the i/c but its still a small system, meaning it doesn't circulate very far. by moving it to the trunk i have made the system longer, and also keeping the coolant temp very low and by doing that keeping my iat temps very cool, and reducing the chance of detonation and a loss of timing, and thierfor not loosing much h.p due to temps and losss of timing
I'm sure you know this but it isn't cooled in the tank! That is what the radiator is for, the one that is part of the intercooler. Don't think you are going to gain much with this but whatever...at least it is unique and kinda cool (no pun intended) looking.
Old Aug 30, 2007 | 11:55 PM
jerjan's Avatar
jerjan
OK, it sounds like you are being innovative. That's cool. But it also looks like alot of extra work for minimal gain. The coolant tank located in the engine compartment is not the radiator, nor does it really absorb as much heat as you think. You would be far better off putting your battery in the trunk, which would transfer alot of weight to the rear and put your ice tank where the battery was. It would also be much better to put a larger intercooler radiator on the car.Check this one outhttp://store.summitracing.com/partde...p;autoview=skuThat puppy has about 6 times the cooling capacity of a stock intercooler. I put one on mine and it kicks booty. By the way, your ice will melt so fast, you will be refilling the tank every 5 minutes. Been there done that. But hey , if you like it go for it.
uberstang1
Dec 7, 2017 07:10 AM
9550
Oct 26, 2015 05:01 PM
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
Oak
Sep 14, 2015 03:08 PM
