Hurst shifter Hard install1-10?
Old Aug 30, 2007 | 07:04 PM
06Redfire3V's Avatar
06Redfire3V
Default Hurst shifter Hard install1-10?
Hey fellas just thought i would ask before i order my Hurst short throw. How hard of a install is it on a scale of 1-10? it's going to be me and a buddy. i have a little knowledge about it the other knows a lil bit as well.
Old Aug 30, 2007 | 07:12 PM
Aziraphale's Avatar
Aziraphale
Default RE: Hurst shifter Hard install1-10?
Not too bad, read this first though (for the MGW but pretty much the same)
https://mustangforums.com/m_3000094/tm.htm
Old Aug 30, 2007 | 07:13 PM
acascianelli's Avatar
acascianelli
As long as you can get under the car its easy. The hardest part is fitting the shifter through the hole.
I give it a 3, slightly harder than installing a CAI only because it envolves lifting the car either with ramps or jack stands.
I'm a car noob and I was able to do it no problem.
Old Aug 30, 2007 | 07:14 PM
Caution's Avatar
Caution
It was really easy and pretty much common sence... you'll be able to do it fast
Old Aug 30, 2007 | 07:18 PM
marcuskeeler's Avatar
marcuskeeler
With 1 being easy and 10 impossible, I'd say it was a 6 with driveshaft in place but a 2 if you drop the shaft off. It's wiggling the shifter through the floorhole which is the fiddly bit.
Old Aug 30, 2007 | 07:23 PM
06Redfire3V
a 6 and 3? hmm.... lol
Old Aug 30, 2007 | 07:26 PM
marcuskeeler
Well, in fairness it wasn't clear which was easiest on his scale, a 1 or a 10 LOL [8D]
Old Aug 30, 2007 | 07:38 PM
howarmat's Avatar
howarmat
s197 Junkie
its a 5
Old Aug 30, 2007 | 08:05 PM
GT06GT's Avatar
GT06GT
-5! [sm=trust_me.gif]
About 5 bolts, slop on some grease and call it a day
Old Aug 30, 2007 | 09:27 PM
ErcWrestlr's Avatar
ErcWrestlr
I would give it a 3 especially if you have a buddy helping you. Just take your time and watch how the old one comes out. I have done it a couple times without ever removing anything but the shifter (no transmission or driveshaft). Fiddle it around and take your time. . . .it will eventually drop in and fit in place.
