Sponsored by:
Sponsored by:
rust starting to show
Old 09-06-2007, 05:22 PM
marcuskeeler
marcuskeeler's Avatar
Default RE: rust starting to show
Like I say, get the oil underspray treatment, it's cheap, cost me $110, and it makes the underside look awesome as well as Protecting it.
marcuskeeler is offline
Old 09-06-2007, 07:31 PM
pascal
S197 Section Modder-ator
pascal's Avatar
ORIGINAL: marcuskeeler
Thanks budd.
pascal is offline
Old 09-06-2007, 07:38 PM
8178A
8178A's Avatar
It is interesting that Ford does not paint many of the suspension and drive train parts.
8178A is offline
Old 09-06-2007, 07:53 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: 8178A
If they did there is no way they could offer the GT at a sub-$30k base price. Besides that I have seen rear ends on 1960's era cars that have surface rust and nothing else, it does not harm anything. If you want a show car paint it all yourselves. Mustangs a a mass produced car, not a hand built show/exotic car.
JD1969 is offline
Old 09-06-2007, 08:01 PM
raubt
raubt's Avatar
ORIGINAL: Nuke
Beware undercoatings! They can retain moisture and cause more damage than they're supposed to prevent.
I just had my car undercoated, and (word on the street is) they wash the car's underside before they undercoat, then let it dry for a while, and once everything is dry, on goes the thick sloppy undercoating.
It could theoretically trap moisture, but since everything is allowed to dry before the undercoat goes on, it shouldn't be an issue at any decent shop.
Anyhoo, if you're worried about rust down below, the undercoating/sealant into the body panels is probably the way to go.
Especially if you live somewhere that it snows and the roads are treated with salt/sand in the winter.
My "rust-proofing" was $450 plus a $50 touch-up once per year from now on. I live in wintery Canada, so body rust is likely after a few years, and this is a relatively cheap way to go considering the thousands of dollars you'd spend on body work/repainting if the car starts to rust in a few years.
On the downside, they ripped one of my rocker-panel stripes and got gooey sealant on my car, but whatever, that's just because they're sloppy assh-les, not because rust-proofing is a bad idea.
raubt is offline
Old 09-06-2007, 08:23 PM
TPony
TPony's Avatar
Wow...rusting already...not good.
TPony is offline
Old 09-06-2007, 08:31 PM
pascal
pascal's Avatar
ORIGINAL: TPony
Go under your car and take a peek.
pascal is offline
Old 09-07-2007, 04:47 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
surface rust sucks but a fact of life with the undercarriage!
mygt500 is offline
Old 09-07-2007, 05:37 PM
STORMEASTON
STORMEASTON's Avatar
ORIGINAL: Nuke
That has to be the dumbest thing yet I've heard on these forums, undercoating is sealant not a sponge! The only way it could trap moisture is ifit was applied when the car was wet, which I'm sure would not happen!I just got done taking the body off a 1967 Galaxie 500, a 40 year old car, the only places that had rust on them were...tada, the spots where they didn't apply the undercoating to. And I might add that stuff is a real bugger to get off metal surfaces!
STORMEASTON is offline
Old 09-08-2007, 05:18 AM
UAE_Muscle
UAE_Muscle's Avatar
thanx for the input
UAE_Muscle is offline
Quick Reply: rust starting to show
