Driver-side over the axle pipe hitting body...
Old Sep 6, 2007 | 03:19 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
Default Driver-side over the axle pipe hitting body...
What can I put under the body of my car right above the driver-side over the axle pipe to prevent the muffler from making a loud metal bang over big bumps?
I do not want to reposition the mufflers because the alignment is perfect. Obviously I can't put anything on the muffler because it will melt (or will it?). Please let me know your suggestions. Thanks!
G
Old Sep 6, 2007 | 03:24 PM
GT06GT's Avatar
GT06GT
Default RE: Driver-side over the axle pipe hitting body...
i have the same problem since my stock muffler on the driver side was to the left a little to far, i installed the bassani's properly in the center but i get the same clunk. Only thing i could find is turn the music uphopefully someone has some better advice
Old Sep 6, 2007 | 03:29 PM
schapman's Avatar
schapman
do you have a picture of the area in question?
Old Sep 6, 2007 | 03:34 PM
Derf00's Avatar
Derf00
Gentleman's Relish
how much clearance between the pipe and body is there to begin with? Less than 1/2"-1"? If it is, you need to find a way to get the proper clearance first before resorting to other ways of fixing it.
Old Sep 6, 2007 | 03:40 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
The clearence has to be less than an inch. I don't mind if it hits....I just don't want that thunk.
Here is a pic of my exact setup (MAC Cat-back system)...
Old Sep 6, 2007 | 04:00 PM
Nuke's Avatar
Nuke
Assuming the pipe is hitting the rear of the axle and NOT the body like you said, my suggestion would be to loosen both the midpipe and axle clamps, ensure the axle back pipe is fully in the rear of the midpipe, then adjust with only the midpipe clamp loose. That way, you SHOULD be able to get a bit more clearance between the pipe and axle. If it IS hitting the body, then I'd loosen it all up on that side and simply realign from scratch.
Rick
[sm=smiley34.gif]
Old Sep 6, 2007 | 10:22 PM
jerjan's Avatar
jerjan
The exhaust pipe alignment can be tricky on these babies, You need to have everything correct, starting from the angles on the off road pipes all the way back to the mufflers. I fixedthis same problem on mine by loosening up everything and adjusting all the angles. Good luck!
KingRando
Oct 2, 2015 08:06 AM
Sep 30, 2015 12:39 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
