Stagered 18x9,18x10 Set
Been reading these forums here for a while but this will be my first post, so hello one and all. I have an 07 that i will be doing a 18' staggered set on soon. I have installed a Eibach pro kit and im wondering what the largest size set of rubber is that i can tuck in with little to no fender rub. So far my investigations on these and other boards suggest 295/40/18's on the front and 255/45/18's on the rear. This sound right? Thanks in advance.
RE: Stagered 18x9,18x10 Set
I have 18x9 with 255 up front, and 18x10 with 275 in back, and i have no rub at all, now i dont have the eibach kit, im stock in that department, so i cant help you there, jus giving you a little insight.........
Welcome. 295s would look awesome, especially if you lower the car. If you get tires to wide for the rim,it will cause your side walls flex ,or bow in the corners, reducing their performance.
ORIGINAL: SkidLid
ORIGINAL: Pantera72
Somebody was running 295/45/18's with the Eiback kit, but I don't recall who. If you want the widest all the way around you should be able to run 275/40/18's up front to.
ORIGINAL: SkidLid
