What Octane do you run?
Old Sep 8, 2007 | 11:07 AM
Gman13's Avatar
Gman13
Default What Octane do you run?
I'm curious what Octane fuel everyone runs. I have always run 93 but after reading some other posts, think I might be wasting money. I don't have a tune yet, just a granatelli CAI. Does 93 make a difference over 87 or 89 without a tune?
Old Sep 8, 2007 | 11:21 AM
GidyupGo's Avatar
GidyupGo
Default RE: What Octane do you run?
No. You are wasting your money if you run anything over 87 on a stock calibration. You may be running lean with the CAI without a tune. Not a good idea.
Old Sep 8, 2007 | 11:22 AM
hammeron's Avatar
hammeron
V power 92
Old Sep 8, 2007 | 11:26 AM
GidyupGo's Avatar
GidyupGo
ORIGINAL: hammeron
V power 92
With a stock tune??? Come on, you're not helping him out here.
Old Sep 8, 2007 | 11:28 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Gman13
Does the particular Granatelli CAI you bought require a tune?
Running lean with a CAI and no tune is BAD news.
Run what the owners manual recommends unless you
have a tune. 93 will not keep the engine from running
lean and cooking things like pistons and valves.
Old Sep 8, 2007 | 11:33 AM
hammeron's Avatar
hammeron
wait he said what octane are ya runnin?
if i saw stock, i would have said 87
ORIGINAL: GidyupGo
ORIGINAL: hammeron
V power 92
Old Sep 8, 2007 | 11:36 AM
Gman13's Avatar
Gman13
[/quote]
[/quote]
The CAI I have does not require a tune. It came with a mass airflow sensor module that plugs in and keeps the ratio correct. So I don't think I'm running lean, but don't think I need to run 93 either.
Old Sep 8, 2007 | 11:43 AM
thxultra's Avatar
thxultra
Stick with 87 for that intake. You will only benifit from 93 if you are running a tune built for 93.
157dB's Avatar
157dB
Cut & Paste Expert
My Airaid came with the plug setup also.
You need to run 87 as the owners manual states
unless you get a tune. Its a waste of about 20 cents
a gallon to run the 93 with a stock tune and a CAI
with a no-tune-required-plug.
Old Sep 8, 2007 | 11:53 AM
PLstang's Avatar
PLstang
I run 93 with a tune and spraying a 125 shot. However, stock I ran....wait...never mind my car went from the dealership to the speed shop. I never ran stock
