Please Help!
Old Sep 10, 2007 | 09:43 AM
Dennis074.0's Avatar
Dennis074.0
Default Please Help!
I just ordered 3 gauges, and I need to know if I need anything else with the gauges.
VACUUM GAUGE
comes with
White Reverse 7 Color Vacuum Gauge
Mechanical Hose Kit
T Fitting
Mounting Hardware
Gauge Visor
Instructions
WATER TEMP GAUGE
Comes with
White Reverse 7 Color Water Temperature Temp Gauge
1/8NPT Temp Sender Unit
Mounting Hardware
Gauge Visor
Instructions
and an OIL TEMP GAUGE
Comes with
White Reverse 7 Color Oil Temperature Temp Gauge
1/8th NPT Temp Sender Unit
Mounting Hardware
Gauge Visor
Instructions
and I'm getting a 3 gauge wire set.
Thanks
Old Sep 10, 2007 | 10:43 AM
A_J's Avatar
A_J
Default RE: Please Help!
I haven't done those guages in a Mustang, but in my past experience, just be ready for a trip or two to the hardware store - depending on how/where you tap into for the water and oil, the 1/8 NPT fittings may need some additional fittings to adapt it to your specific application..
Old Sep 10, 2007 | 10:52 AM
Dennis074.0
thank you.
Old Sep 10, 2007 | 11:20 AM
A_J's Avatar
A_J
I'll add that with the oil gauge, sometimes you need to get an adapter plate that goes between the oil filter and the block to get a tapped outlet for the sending unit - but I have zero knowledge if that's required on the 4.0..
